Author Topic: 66 Fastback Trunk Lid, Grill, Gas Cap  (Read 832 times)
Offline bpmdu
« on: July 29, 2022, 03:50:51 PM »
Looking for a nice original trunk lid for a 66 fastback, a show quality original grill (just the grill, not the entire assembly), and a NOS gas cap.
Offline bpmdu
Re: 66 Fastback Trunk Lid, Grill, Gas Cap
« Reply #1 on: August 11, 2022, 11:32:30 PM »
Also searching for nos non-gt horse/corral ornament for grill.
« Reply #2 on: August 12, 2022, 12:59:14 AM »
Are you looking for a particular date for the trunk lid?  Just trying to help you get the best match possible.
Offline bpmdu
« Reply #3 on: August 12, 2022, 01:32:41 AM »
Did they vary during production? Honestly, not that familiar with the trunk lids. April 66 build date. Car had to be redone after being in a hailstorm and I idiotically decided to go with a dynacorn trunk lid that fits terribly.
« Reply #4 on: August 12, 2022, 03:25:33 PM »
The shape and design did not change that I'm currently aware of = just thought if you were looking for matching or original date pattern on your parts you might want to mention it in the request
Good luck with your search
Online jwc66k
« Reply #5 on: August 12, 2022, 03:38:34 PM »
A 65 trunk lid will fit, but it has different bracing. The hinges are the same. The only problem you may encounter is if the torsion bar retainer spring nut, 380264-S2, is missing or damaged. It is not reproduced.
« Reply #6 on: August 13, 2022, 01:05:24 AM »
A 65 trunk lid will fit, but it has different bracing. The hinges are the same. ..............
You can use the different versions of 65-66 fastback hinges on each year but there are different ones for different production periods as discussed in those sections of the site.  Two different ones used on the drivers side in 65 and if I recall correctly three versions of the passenger side
For originality just stick with the 66 trunk hinges and you'll be fine bpmdu :)
« Last Edit: August 13, 2022, 01:12:53 AM by J_Speegle »
Offline bpmdu
« Reply #7 on: August 13, 2022, 12:18:14 PM »
Appreciate the info guys, at this point I?d take a 65 or 66 bc the current fitment bothers me quite a bit! Hinges are correct on mine currently at least
Offline pjg01
« Reply #8 on: January 30, 2023, 11:21:53 PM »
are you still looking for a decklid i have a 66 to sell.
Paul
