Author Topic: Leaf spring bolts  (Read 1702 times)
Offline preaction
Leaf spring bolts
« on: September 18, 2022, 03:52:46 PM »
I not sure what the technical name for these are but its not in a search. Im restoring a set of rear leaf springs and the fastner and nut (its round at one end) that goes through the center of the stack doesnt  to want to part from the leaf stack is there a good replacement for one of these fastners ?
Re: Leaf spring bolts
« Reply #1 on: September 18, 2022, 04:17:29 PM »
Leaf spring centering bolt. NPD has them .There are two different heights used depending on the application because for example 9 inch rear hipo Mustangs used a taller centering bolt . https://www.npdlink.com/product/bolt-leaf-spring-centering/201888    . https://www.npdlink.com/product/bolt-leaf-spring-centering/201887
« Reply #2 on: September 18, 2022, 04:19:13 PM »
I assume your signature car, a 68. Did you look in the library in the 67-68 Mustang Hardware Spreadsheet by application, "Spring, Rear"?
