Author Topic: Neutral Safety Switch C6  (Read 359 times)
Offline Tiny
« on: December 23, 2022, 02:57:02 AM »
Hi all, I am trying to install my neutral safety switch as per the instructions I have seen online-place drill bit in the small hole, rotate the mechanism until the drill bit slides in all the way. No problems.  My issue is when the vehicle is in park the spline in the neutral switch grooves are horizontal whilst the shifter lever are vertical.
If I rotate the neutral switch to suit the shifter then I dont get any connection to the starter motor in any gear.
Is there something I am doing wrong?  Is the C4 neutral switch the same as a C6.
Thanks guys
67 San Jose Built GTA 390 Coupe
C6, PS, A/C
Offline Tiny
Re: Neutral Safety Switch C6
« Reply #1 on: December 23, 2022, 05:50:21 PM »
Hi all, my bad.  I should have the shifter in neutral when fitting the switch not in park.
all good
Have a great xmas
C6, PS, A/C
« Reply #2 on: December 23, 2022, 06:23:05 PM »
Sorry I didn't actually choose to read your post earlier today, I knew about the adjustments being in neutral and was about to comment right now and then read reply #2 (your own). I laughed.
Merry Christmas 🎄
« Last Edit: December 23, 2022, 07:37:42 PM by 67gtasanjose »
Offline Tiny
« Reply #3 on: December 23, 2022, 06:25:36 PM »
cheers mate
thanks
C6, PS, A/C
