Author Topic: 1966 Convertible Top Motor, Lifts, & Hardware  (Read 8609 times)
Offline Pete Bush
Re: 1966 Convertible Top Motor, Lifts, & Hardware
« Reply #15 on: April 13, 2011, 08:21:43 PM »
Thanks, Dave.
Looks like the replacement cylinders look very similar to the originals.
'66 6-cylinder Sprint Convertible
Metuchen - Scheduled May 10th; Built June 21st
Offline Pete Bush
« Reply #16 on: April 17, 2011, 08:47:52 AM »
Received a second top motor yesterday (pictures below). Between the two, I can select the best parts to make one good one.
The curious thing is the date code highlighted in the yellow box. Instead of reading 6E like Dave's, it reads E6. The characters are transposed.
It also looks like the remnants of a number stamp on the bottom of the bracket (motor side). It's difficult to tell, but it could be the same as Dave's 16511 stamp.
Offline Pete Bush
« Reply #17 on: April 20, 2011, 07:51:09 PM »
Looks like my vert is also missing the junction block that attaches to the fender by the starter solenoid. Does anyone have any pictures of the hook-up?
Offline Twilight65
  • Gold Level Subscriber
« Reply #18 on: April 20, 2011, 09:02:54 PM »
Pete,
Here's a picture of mine.  I also rebuilt my block. Have attached that pic also.
Dave
Offline Pete Bush
« Reply #19 on: April 20, 2011, 09:30:36 PM »
Thanks, Dave.
Is the paper formed the way it was on the original? Looks slightly different than the repos.
Is that black tape at the top of the fusible link? Or a tag of some sort?
Offline Twilight65
« Reply #20 on: April 20, 2011, 10:32:16 PM »
Pete,
The paper is correct. There was a complete thread(see below)on it when I was trying to restore mine. Pete Morgan had a picture of a NOS one. As to the fusible link, that was remnants of the original wire tag.
Dave
http://www.concoursmustang.com/forum/index.php?topic=747.msg4101#msg4101
Offline Pete Bush
« Reply #21 on: April 21, 2011, 06:49:42 AM »
Excellent information there.
That's exactly what my PO did; attached the fusible link directly to the top wire and taped it up. No junction block.
I was thinking about buying the repo junction block and re-forming the paper to conform to your picture, Dave. But when I compare the two side by side, the repo doesn't look long enough to accomplish the necessary bends. If that happens to be the case, is there a source to by a small piece of the appropriate paper?
Pete
Offline Twilight65
« Reply #22 on: April 21, 2011, 04:59:32 PM »
Pete,
I have paper if you need it and the Dims. to bend it to.
Dave
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #23 on: January 02, 2012, 08:11:00 AM »
Dave!
How much would you charge me to supply me a piece big enough to make one?
And the dimension drawing, of course.
BC
66 Metuch Conv
Nightmist, Std Blu Int
Offline Twilight65
« Reply #24 on: January 02, 2012, 12:35:32 PM »
Bryan, sent you a PM.
Dave
Offline 66RavenGTCoupeAgain
« Reply #25 on: June 02, 2018, 09:58:06 PM »
Hi Guys,
Just a quick slightly off topic question if I may?
Am I able to bench test my motor by just hooking it up to a battery? I understand that the black terminal is negative and the other two yellow and red ones are up and down. When I say "bench" test, Im kind of lying as the motor is in the car but not all of the wiring is done yet so I would like to test and prime it before I go any further.
Would connecting a battery directly to the plug that comes off of the pump do any damage?
Also, if I could ask what fluid is recommended as I have read that some are saying brake fluid and others transmission fluid? (Brand/Type?)
Thanks in advance,
Dan.
66 Metuchen NJ  GT Coupe
Raven with Deluxe Black Int 289 A Code C4 PS Tinted Windows (Green) Dealer installed Rear Speaker
6T07A1612## Dec 65 Build
65 San Jose CA Convertible Rangoon Red with White Int and Power Top with plastic rear window 289 C Code C4 PS PB AC Fog Lights
5R08C1496## Oct 64 Build
« Reply #26 on: June 02, 2018, 11:22:11 PM »
If you just want to tap the wires to the battery to see if anything happens, that's fine.  Don't run the pump for an extended period without fluid.
« Reply #27 on: June 03, 2018, 12:16:17 AM »
Yes, yes and yes,
I make up "jumper" wires, an alligator clip at each end, to do that. As Charles stated, a short connection of 2 or 3 seconds should not cause any problems.
AT fluid is recommended, type F (for Ford). Almost any major brand is fine.
If you haven't done so yet, get a set of 66 Mustang Assembly Manuals. To "complete" the set, a "64 1/2-65 Chassis Manual" and a "64 1/2-65 Weld and Sealant Manual" should be considered.
Offline NEFaurora
« Reply #28 on: June 03, 2018, 04:49:23 PM »
"AT fluid is recommended, type F (for Ford). "
Not any more.  Actually, This has changed a long time ago.  Type "F" is a caustic Fluid and has been found to make rubber seals and especially the plastic hydraulic lines extremely brittle over time and accelerates age and cracking of the pump seals and pump plastic fluid lines.  It was found that the Dexron-Mercon type fluid did not do this, so that is what is recommended not only for today's convertible top pumps, but for old Ford Top pumps and lines as well.  Go with Dexron-Mercon instead, because it's better stuff and it will be much nicer to your pump seals and fluid lines.  If you still want to use "TYPE F" for your Tranny, go ahead...but don't use it for your convertible top pump and lines.
:o)
Tony K.
MCA#70001
« Reply #29 on: June 04, 2018, 12:46:20 PM »
I did not know that. My only convertible did not have a power top.
