Author Topic: WTB 67 SJ front strut rod hardware  (Read 696 times)
Offline Texascobra
« on: February 24, 2023, 06:47:08 PM »
Looking for correct front strut bar hardware (serrated washers and front and back nuts) for 67 Shelby.
65 427SC 4123
67 GT500 752 1/23/67
96 Cobra American Iron Racer
12 GT500 Daily Driver
Re: WTB 67 SJ front strut rod hardware
« Reply #1 on: February 24, 2023, 07:20:16 PM »
Try AMK products.
Offline Texascobra
« Reply #2 on: February 25, 2023, 04:17:00 PM »
I have the AMK nuts although I am not sure if the finish are correct on them. They do not have the washers. Mine are without serrations and have a brite finish.
65 427SC 4123
Online jwc66k
« Reply #3 on: February 25, 2023, 04:34:24 PM »
Assuming that this is for a regular production Mustang, you should check this forum's library under topic "Mustang Hardware Spreadsheet 67-68". You will find two spreadsheet files, one by Ford part number, MHW67-68PN06.xlsx, the other by use (application), MHW67-68AP06.xlsx (the "06" is the revision in both files). These files were based on the Mustang Assembly Manuals, Ford Car Parts (aka MPC, for service numbers), and other sources.
If you do not have a set of the 67 Mustang Assembly Manuals, I recommend you get a set.
« Reply #4 on: February 25, 2023, 09:53:19 PM »
The washers were also reproduced (by Scott Drake I believe) and the serated nuts were Phosphate &Oil while the forward lock nuts were zinc ( the nuts should be available through AMK).
I just looked at NPD'S site and they stock what you need, short of being authentic Ford parts.
« Last Edit: February 25, 2023, 09:58:52 PM by 67gtasanjose »
Offline 67350#1242
« Reply #5 on: February 26, 2023, 09:14:59 AM »
I have an OEM set both sides (came in a Moog box) with 2 serrated (rear) nuts, correct bushing inserts, Harris bushings with correct markings.  It has 4 smooth washers but I can add 2 of the serrated washers (Drake).   $100 plus shipping. (Sold)
Let me know and I will post pictures.
Kurt.
« Last Edit: February 28, 2023, 02:25:29 PM by 67350#1242 »
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #6 on: February 26, 2023, 03:42:22 PM »
The washers were not bright silver and they did have serrations . They did not have the word FRONT stamped into them like aftermarket washers typically do.
Offline Texascobra
« Reply #7 on: February 28, 2023, 04:28:11 PM »
I missed the above offer so I am still looking for the washers.
65 427SC 4123
Offline Texascobra
« Reply #8 on: February 28, 2023, 04:39:17 PM »
Found them!
65 427SC 4123
