Author Topic: Accelerator Linkages Painting?  (Read 4221 times)
Offline LouisGT350H
« on: April 16, 2023, 06:55:17 PM »
I have a 1966 hertz shelby.   Can any one advise how the accelerator linkages were painted?   They look like part were painted blank and some of them left a natural blank zinc color?
« Last Edit: April 16, 2023, 11:11:34 PM by J_Speegle »
Re: Accelerator Linkages Painting?
« Reply #1 on: April 16, 2023, 06:59:43 PM »
no paint on any parts there. all plating. either zinc or p&o.
« Last Edit: April 16, 2023, 11:11:41 PM by J_Speegle »
« Reply #2 on: April 16, 2023, 11:07:03 PM »
Are you asking about the linkage between the acceleration bell crank/arm attached to the firewall and the carburetor? As offered nothing is painted as far as linage or rods, but finish depends on the specific part.
Might be able to answer your own question if you look through the unrestored picture thread. For this need I suggest a thread titled Late 66 San Jose C Code Coupe- Unrestored Picture Thread. Most likely the answer is in the initial posting
« Last Edit: April 16, 2023, 11:11:49 PM by J_Speegle »
Offline LouisGT350H
« Reply #3 on: April 17, 2023, 05:53:38 PM »
These are the parts I was talking about, the accelerator linkages.
As you can see from the pic, looks like the part which goes in engine bay is painted mat, but the part inside the car which the pedal is on is left grey unpainted?
Regards
« Last Edit: April 17, 2023, 05:56:22 PM by LouisGT350H »
« Reply #4 on: April 17, 2023, 05:58:07 PM »
The section from inside the car where it was more protected from the elements confirms the phosphate original finish. Just need to clean and replate the item then put a protective coating on it
Lots of things and surfaces get painted in the engine compartment by prior owners trying to fresh up the look or cover over other things
Offline LouisGT350H
« Reply #5 on: April 17, 2023, 06:22:01 PM »
Thanks for your help. : ;D
