Author Topic: Power Steering Cylinder Washers  (Read 927 times)
Offline kkupec02
« on: April 29, 2023, 05:48:53 PM »
I can't tell by pictures. On the straight shaft of the cylinder rod, there are a thick rubber washer and a metal washer on each side of the bracket. I took off two "cupped" metal washers. When I got the rebuild back, it came with two flat metal washers. Which is correct? Thanks.
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
Re: Power Steering Cylinder Washers
« Reply #1 on: April 29, 2023, 06:01:38 PM »
who did the 'rebuild'? i believe the cups are correct.
Offline kkupec02
« Reply #2 on: April 29, 2023, 10:49:51 PM »
ChockoStang. $100 plus shipping with 2 day turnaround. Cylinder looks nice.
« Reply #3 on: April 29, 2023, 11:15:24 PM »
Flat washers will work but cupped zinc silver washers are factory correct.
« Reply #4 on: April 30, 2023, 12:05:09 AM »
Not originally flat but they are slightly cupped but not heavily (or double) cupped like you find on replacements. Think the zinc double cupped style is likely what your thinking since they are so commonly found and seen on older Fords.
Believe you will find that allot of the boots were ripped and damaged early in life so you will find allot of them have been replaced with the later deeply or double cupped washers on the inside and outside of the bracket.  Often the plating is much nicer that other plated hardware of the same type on the same car.
Here is what I found
Examples of the slightly cupped washers retained on the whee side by a single nut. Have a fair collection of examples exactly like this from 67 San Jose cars. Would have to look at a lot more pictures and documents to see if and or when the double cupped washer was used on the assembly line. Just focused on 67 San Jose since that is the focus
Matching the service replacement kit at the top of the picture and two examples where the car got the boot repair kit. Notice that the kit included two nuts. A regular one and a sheet metal locking one
Picture of one of the kits showing the washers and other hardware that was sold into the 90's at least
Noticed that your car when you got it appears to have had the slightly cupped on rather than the one shown above
Opinions can and will vary :)
« Last Edit: April 30, 2023, 12:07:23 AM by J_Speegle »
Offline kkupec02
« Reply #5 on: April 30, 2023, 12:44:20 AM »
Where would you find that oddball metal band/strap that holds the 2 pressure lines at the tube ends to the steering rod, probably not what it is called. I had to cut mine off.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #6 on: April 30, 2023, 01:19:44 AM »
I think your asking about the worm gear hose clamp that was used - see photo.
Ford probably used more than one vendor for these....I think the main thing if you want to be accurate as possible is find an older one that does not have the sizes marked in millimeters like all the current production ones do today.
20230429_210317 by Marcus Anghel, on Flickr
Marcus Anghel
www.anghelrestorations.com
« Reply #7 on: April 30, 2023, 08:07:47 AM »
The crinp-style clamps found on 67's is not reproduced and only found on original cars, and even then, typically found only cars that have hoses which haven't been replaced.
You really shouldn't cut one off since they are made out of a rare material called unobtainium.
More information about that clamp and other parts pertinent to a 67 small block Mustang.found in this thread: https://www.concoursmustang.com/forum/index.php?topic=10247.0
« Last Edit: April 30, 2023, 08:57:03 AM by 67gtasanjose »
Offline kkupec02
« Reply #8 on: April 30, 2023, 11:18:05 AM »
Damn. I couldn't figure out how to get it off since it was solid where it was visible to me and the "connector" was on top and out of sight. It felt like it was kind of crimped and it wasn't going to come off. I finally cut it off.
