Author Topic: Gas Tank Sending Unit Build-up - 70  (Read 2115 times)
Offline ClevelandKid
« on: June 18, 2023, 12:02:23 PM »
Just swapped out my 70 Mach 1 sending unit as it stopped working. Why is the float all green? It looks like moss on a tree. Could this be the effect of running E10 gas? I switched to Non ethanol a few years ago but until then I could only get E10. The stock float is brass like the replacement. Have a look. Your thoughts.
« Last Edit: June 18, 2023, 05:06:51 PM by J_Speegle »
Mustang country. Get the women,kids and Chevys off the streets.
Re: Gas Tank Sending Unit Build-up - 70
« Reply #1 on: June 18, 2023, 05:06:19 PM »
Brass floats will typically chance color due to what ever they are exposed to. This even takes place when exposed to water.  Since our fuel is often a single product or a combination of things as well as often water  (from contamination or moisture/condensation) this is "normal". Guess someone could search for all the scientific reasons and explanation on the web. Its surely there.
The collection on your float looks different from others I've seen as far as texture and build up but no telling what is in the fuel in your area or from your supplier
Bottom line, since your driving - check and or change the fuel filter since there is a good chance that some of this is floating in the fuel system and will create issues for you in the carburetor at some point.
Retitled the thread slightly and I'm moving this to a more general area so that more eyes see it since it applies to all years and models
Offline rockhouse66
« Reply #2 on: June 18, 2023, 09:43:02 PM »
Weird.  It looks like a Chia Pet!
'66 GT FB
« Reply #3 on: June 18, 2023, 10:49:43 PM »
I bet if you clean it up and remove the cover from the resistance coil and clean it up it will work better than the repop in the picture.
Offline preaction
« Reply #4 on: June 18, 2023, 11:11:43 PM »
The condition of your sender is a good indication of what the inside of your gas tank looks like.
« Reply #5 on: June 18, 2023, 11:29:52 PM »
Agree. Plus the reproduction sending units only work briefly. Recommend you send the original unit to Bill Basore for repair. Then buy a new gas tank and put both in together. Only use 110 octane race gas after that.
« Reply #6 on: June 19, 2023, 01:07:08 PM »
Some lite reading about copper corrosion.
https://www.corrosionpedia.com/definition/1642/copper-corrosion
