Author Topic: Rear Brake Lines  (Read 2024 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Rear Brake Lines
« on: April 27, 2011, 07:58:03 AM »
I bought prebent brake lines for the rear axle.  I have installed Arvinode and am doing the brakes "AS IF" factory.  The line to the right wheel is perfect.  The line to the left wheel is about 5" too long.  I guess I'll have to get a double flaring too and cut it off.
66 Metuch Conv
Nightmist, Std Blu Int
Re: Rear Brake Lines
« Reply #1 on: April 27, 2011, 09:08:32 AM »
Are you using a dual exhaust brake hose?  Might be what the difference is if you didn't order lines to match.  Or, could simply be a mistake by the vendor/manufacturer.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: April 27, 2011, 10:15:02 AM »
Yes Charles,
I bought the Dual Exhaust long line to firewall, the "L" bracket to relocate the connection to the dual exhaust spot, the dual exhaust rubber hose, the dual exhaust vent line hollow bolt, and the dual exhaust brake lines.
I know there were two widths of rear axle housings.  Maybe the prebent left line is for the longer one.
66 Metuch Conv
