Author Topic: 69 Boss 302 Power Steering  (Read 9547 times)
Offline hopey
Re: 69 Boss 302 Power Steering
« Reply #15 on: June 24, 2023, 07:22:08 PM »
Here are pictures of the 69 B2 Pump end pressure.
Part number C9ZA 3A719 D,  yes D.
Dan,
That is an engineering number, not the Ford part number.
1970 BOSS 302
Built 11/15/69 Dearborn
Offline chockostang
« Reply #16 on: June 24, 2023, 08:18:51 PM »
What is the part number for this particular hose with this type fitting?
« Reply #17 on: June 24, 2023, 11:38:27 PM »
From a late 69 MPC. As a reminder for others the oil cooler *listed below the wo/oil cooler group shown below, was not an option nor available from the factory on production 69 Boss 302's, so can't explain why Ford would list it other than just an error/miscommunication. Since Ford was always consolidating parts to reduce the need for additional inventory we can't be certain that the part numbers shown are the exact ones that were installed on the line, even only a couple of months after production had ended.  Guess another place to look is the Assembly Manual reprints but don't know if they list the application
Sorry don't have a MPS printed between May and Aug 69
« Last Edit: June 25, 2023, 12:04:52 AM by J_Speegle »
« Reply #18 on: June 25, 2023, 07:44:00 AM »
Dan,
That is a part number indeed - you can call it an "engineering part number", or "casting part number" but it is still a "number" on a "part".  I've seen some Ford documents also refer to parts using the very generic "item number" terminology.
What it is not is the "service part number".  The Ford "Parts and Accessories Catalog" (with varying names including, depending on the specific publication, the "Master Parts and Accessories Catalog" (see the attached and often abbreviated as the MPC) lists the service part numbers.
Sometimes the item number (engineering number, casting number, etc.) is one and the same as the service part number.
Offline chockostang
« Reply #19 on: June 25, 2023, 09:50:28 AM »
So that is saying a cooler was not a option???  This B2 has a cooler and hoses are certainly original.
Did Ford dealer install these?  If dealer installed can it be considered original?
Online jwc66k
« Reply #20 on: June 25, 2023, 11:49:35 AM »
B I N G O !
Someone else that understands.
« Reply #21 on: June 25, 2023, 12:24:47 PM »
Thanks Jim.  I guess I should since I designed a few Ford parts that are in the books.
Quiz: When it a service part number technically not for a part?
Answer: When it represents a kit (that is comprised of multiple individually serviced parts...and occasionally with some of those serviced parts that are assembled from several individual engineered parts, each of which have part numbers...)
Offline Mike Bauman
« Reply #22 on: June 25, 2023, 01:28:53 PM »
I believe the MPC is referring to with and without "POWER STEERING OIL COOLER".  In the text for the 69F 302 "with oil cooler" the MPC includes line item part numbers for the bulk return hose and insulation used with the power steering oil cooler. The text for 69F 302 W/O oil cooler does not include those items.  My extra NOS 1969 Boss 302 Power steering Pressure Hose is Tagged C9ZZ 3A719-C...... the engineering number stamped on the fitting is difficult to read (chokostang shows a photo of the eng # as-D).  The length of this hose is definitely NOT 27 inches as the C9ZZ 3A719-A (69F 302 W/O Oil Cooler).  If anyone would like detailed photos or measurements of installed system or loose NOS hose I can supply..... To my knowledge the C9ZZ-C hose has not been reproduced and is very difficult to find NOS or used!
Online jwc66k
« Reply #23 on: June 25, 2023, 02:33:01 PM »
Some of my "Ford" designs are in space, as in Ford Aerospace & Communications Corp.
« Reply #24 on: June 25, 2023, 03:21:06 PM »
I believe the MPC is referring to with and without "POWER STEERING OIL COOLER".  ......................
Were 69 Boss 302's with PS built without the oil coolers for PS ?  If so, when and if we know, why?
Offline chockostang
« Reply #25 on: June 25, 2023, 06:19:31 PM »
Yes, I have heard both versions,  I never got this cleared up in my head for 20 years.  See cars with BF pumps,  "Owner says-That is totally original",  69's with Bottom radiator hose on Drivers side, steel cradle- "Owner===That is totally original-late 69".
I'm very convinced the PS option was a option on 69 using the C7AA Aluminum bracket, the steel support with no hole, the C9ZA 3A719 D numbered pump end pressure, the lower hoses same as 351W.Pump a HBA BK (Return turn 90 degrees straight down, and with a cooler.
Sure do appreciate all that chimed in here.  Kerry Mcmann and I can discuss the situation.
Offline 73mockone
69 BOSS 302 Power Steering Pressure Hose
« Reply #26 on: July 14, 2023, 10:14:44 AM »
I am attempting to find a replacement for the power steering pressure hose for my 1969 BOSS 302, what I believe to be C9ZZ 3A719-C.  I also understand form the forum that this part is extremely hard to find and is not to my knowledge being reproduced.  Assuming NOS or used original cannot be located, what would you suggest as the most suitable alternative?
1969 Mustang BOSS 302  9F02G
1971 Mustang BOSS 351  1F02R
1973 Mustang Mach 1  3F05Q
Re: 69 BOSS 302 Power Steering Pressure Hose
« Reply #27 on: July 17, 2023, 06:41:21 PM »
Given the site and our focus I don't believe there is a suitable alternative. Would guess that your going to have to find or make something that will make the power steering work while you wait and search for something better
Going to add your post and thread to the other related thread on the same subject
« Last Edit: July 17, 2023, 06:52:42 PM by J_Speegle »
« Reply #28 on: July 18, 2023, 01:54:13 PM »
Often times, Boss 302 engines would have a designation of "Special", to differentiate them from the common F code 302-2V engines. (same as K code 289)
The G code Boss 302 engine, was introduced mid year 1969, we might not always find it in some versions of the MPC. I looked up the those hoses in my Mercury MPC. No listing for the Boss2 engine specific engine either. Posting findings from 1969 and 1970.
