Author Topic: 1970 Mustang 428 CJ Convertible Motor Mount  (Read 549 times)
Offline Myfo28
« on: July 23, 2023, 04:53:45 AM »
Anyone out there know the assembly line part number or service replacement part number for the motor mount rubber insulator?
« Last Edit: July 23, 2023, 05:03:32 AM by Myfo28 »
Ravens Black
R Code
Re: 1970 Mustang 428 CJ Convertible Motor Mount
« Reply #1 on: July 23, 2023, 01:14:56 PM »
Are you wanting the engineering number that is made into the assemblyline rubber mount or the replacement part number that is in the books?  ;). They are two different numbers that do not match each other plus the part number in the book may represent a replacement part that will work fine but may look different then assemblyline.
Offline Myfo28
« Reply #2 on: July 23, 2023, 04:51:17 PM »
Bob,
I?m looking for the replacement part number and also the engineering number stamped on the insulator.  Hope I?m stating this correct.  I?ve done some research that says 1969/70 CJ Convertibles requires a specific insulator.
Ravens Black
R Code
Online jwc66k
« Reply #3 on: July 23, 2023, 05:04:58 PM »
Did you look in this Forum's library? There are links to "Ford Car Parts" (aka MPC, 1975 edition) that should give you the information you need.
Offline Myfo28
« Reply #4 on: July 23, 2023, 09:32:02 PM »
Thanks Jim!
Ravens Black
R Code
« Reply #5 on: July 23, 2023, 11:32:58 PM »
Bob,
Yes originally the mounts for convertibles were different for many of the years. The MPCs will only provide the part number not the engineering number.. At least the last version of the MPC that Jim aimed you to has the same part number as they had in 1969-1970 when the cars were built. That is not always the case when comparing different printings of the manuals
Offline Myfo28
« Reply #6 on: July 26, 2023, 10:25:21 AM »
Thanks Jeff!
Ravens Black
R Code
