Author Topic: 1966 Mustang Smog Canister  (Read 1446 times)
Offline Kascus
« on: January 29, 2024, 02:03:13 AM »
Is there supposed to be a filter in this type of smog canister?
Current:
1964.5 289 D Code Coupe / Dearborn 06-05-64
1966 289 C Code Convertible /San Jose 02-11-66
Past:
1965 Shelby SFM5S561
1968.5 428 CJ Fastback / San Jose 05-15-68
1966 289 FB
1965 289 Coupe
1969 302 Fastback
Re: 1966 Mustang Smog Canister
« Reply #1 on: January 29, 2024, 12:28:04 PM »
Yes. It is typically foam with a metal mesh holding it into shape.
Offline Kascus
« Reply #3 on: January 29, 2024, 03:04:49 PM »
Thank you! Any idea of where I can get one? Only a couple of vendors I found listed them and they all say out of stock or discontinued. Are there any alternatives that would work?
Current:
Past:
1966 289 FB
1965 289 Coupe
1969 302 Fastback
« Reply #4 on: January 29, 2024, 03:18:01 PM »
As discussed in the other thread I believe there is no body selling them and originals/NOS have long dissolved in the oil they were packaged with.
Since they are not visible have seen people make and shape open cell foam for this purpose
Offline Kascus
« Reply #5 on: January 29, 2024, 03:31:59 PM »
Thanks, I just read the post that suggested 1/2" thick open cell foam. Guess a trip to the hardware store or fabric shop is on today?s agenda. The car I just purchased has nothing in the can. I am on the East coast so I am not use to seeing smog set ups on a 66.
Current:
Past:
1966 289 FB
1965 289 Coupe
1969 302 Fastback
« Reply #6 on: January 29, 2024, 03:59:22 PM »
Agreed. Nobody is selling them. NPD did at one time (as stock number "9A496-1A", the one I have seems to have a package date code of 9144, 1991, 44th week?). In the "1966 Comet, Falcon, Fairlane and Mustang Shop Manual", section 20 pg 8, that details replacing the smog pump filter, there is no reference to any oil, in fact it states - "Be sure the parts are dry before installing them." I did have an original (or "service", it came with the smog system) and it "disintegrated" over time (don't we all). It was a dark gray, almost black, and it did have the Ford engineering part number in raised (or indented, I don't remember) on it. The service stock number (per "60-68 Ford Car Parts" - aka MPC) is "C6AZ-9A946-A".
Measurements of the NPD filter are: 1/2 in wall (aka thickness), 1 1/2 in ID, 2 1/2 in OD, 2 5/8 in H. It is an open cell foam. Based on the ID, the calculated length of a flat piece of foam would be 4 3/4 in long, and based on the OD, it would be 7 3/4 in long. Cut the long version first, fit it in the "can" and the perforated metal cylinder attached to the can cover, then "trim" as necessary. I would use 3M8008 sealer to join the end to make a cylindrical sleeve.
« Reply #7 on: January 29, 2024, 04:19:54 PM »
Hobby lobby and other hobby stores are possible sources for foam too.
Offline Kascus
« Reply #8 on: February 02, 2024, 03:01:13 PM »
Thanks for the help y?all.  I could not find the correct thickness at Hobby Lobby or Joann?s fabrics so I ordered off Amazon. They had 2 9x9 pads for less then 10.00 so I have a few spares on hand now.
« Last Edit: February 02, 2024, 04:29:19 PM by Kascus »
Current:
Past:
1966 289 FB
1965 289 Coupe
1969 302 Fastback
« Reply #9 on: February 02, 2024, 03:18:34 PM »
Thanks for the help y?all.  I could not find the correct thickness at Hobby Lobby or Joann?s fabrics so I order off Amazon. They had 2 9x9 pads for less then 10.00 so I have a few spares on hand now.
I typically like to support local business whenever possible so I have always resisted Amazon ,Walmart etc.  However I have succumbed to the convenience.  I never would have thought just a few years ago that I would use Amazon for so much as I do today. It typically saves me time and money not having to run all over to find some odd ball thing. And it is delivered to my door.
« Reply #10 on: February 02, 2024, 06:44:08 PM »
Yes let us know how it works. BTW and not that it makes any real difference int he operation the original color was a white or off white
