Author Topic: Looking for someone that can replace a tie rod boot  (Read 3010 times)
Offline Beeler422
« on: February 26, 2024, 08:57:31 AM »
I've got an original tie rod and the boot has a hole in it.  Where can I send it to get a new boot installed?  Thanks.
Offline dkknab
Re: Looking for someone that can replace a tie rod boot
« Reply #1 on: February 26, 2024, 09:11:07 AM »
You can very easily do this yourself. I did mine.   I got the boots from npd. You can get them off using a brass punch (I'm not sure that's the proper name for the tool) and gently pushing the old boot off. The new one can be pressed on using a big socket or the same punch.
David Knab
289 2V, AT, PS
Nugget Gold Interior
Offline Beeler422
« Reply #2 on: February 26, 2024, 10:07:04 AM »
Ah OK.  Thanks for that.  I just thought you needed a special press or equipment to do it.  I'll look a little closer at it.  If anyone has any pics that would be helpful!
Offline dkknab
« Reply #3 on: February 26, 2024, 12:06:33 PM »
If you do a search on the forum I'm confident you'll find many threads about this. Here is one I've contributed to with some pictures.
https://www.concoursmustang.com/forum/index.php?topic=26547
David Knab
289 2V, AT, PS
