Author Topic: Help with rim blow switch  (Read 3174 times)
Offline Tomdeg
« on: April 04, 2024, 11:19:34 AM »
Hey All,
Replacing my new to me ?69 GT350 rim blow switch. It was rock hard when taking the old one out and I spent the better part of yesterday chipping all the petrified rubber ( or glue) out.
My problem is when I went to put the new repro switch in, it did not want to go in without a fight. Of course I ruined the switch in the process. I did notice that the gap in the wheel is about 2mm smaller than the width of the switch. Is this normal? If it matters, the wheel is dated July 68. The gap on the wheel is approximately 7.5-8mm and the switch is about 10mm.
Tom
Offline Tomdeg
Re: Help with rim blow switch
« Reply #1 on: April 06, 2024, 11:09:06 AM »
Does anybody know what the width of the gap should be? Maybe the gap has shrunk?
« Reply #2 on: April 06, 2024, 01:12:50 PM »
Try contacting these guys:
https://www.rimblowrestoration.com/
« Reply #3 on: April 06, 2024, 05:41:10 PM »
Way back when (around 1972) a friend bought a used 1969 Sportsroof (H code, FMX) with the rim blow horn. It didn't work back then either. Just a heads up.
Offline P3sons
« Reply #4 on: April 09, 2024, 11:20:22 PM »
Your new switch has to be installed without any restrictions. 2mm of interference is too much!
As you discovered, if you force the new switch in, or pinch it, it can be permanently destroyed.
There are several manufacturers of the switches so I assume they are not all identical, and widths may vary.
The steering wheels are/were subjected to lots of sunlight and heat.  This results in cracking and shrinking.
The switch trenches do shrink up!
Paul Steinborn  Classic Automotive Ltd
1965 GT convertible K code San Jose 5R08K202XXX  3/26/65
1971 Boss 351  Dearborn  1F02R214XXX    6/9/71
1969 Mach 1  R code  Metuchen 9T02R175XXX  2/24/69
« Reply #5 on: April 11, 2024, 09:54:58 AM »
Paul who makes the best repo rimblo switch ?   The last repo i used was the carpenter switch and i had problems so ended up using an nos switch.
Offline P3sons
« Reply #6 on: April 11, 2024, 11:24:57 AM »
We've been using the Carpenter switches for years.
Upon receiving, I check them all with a meter.  Its a hassle but its important. Occasionally, I find a bad one  "as received".
Without checking, you would never know it was bad--and would falsely blame it on the installation!
During the installation process, we also use the meter to confirm the switch is not being grounded out.
Offline Tomdeg
« Reply #7 on: April 13, 2024, 02:13:19 AM »
I wised up and took it to Rimblow Restorations. I?ll let them put the new switch. Thanks for all the help.
