Author Topic: 69 A/C air duct clips  (Read 2623 times)
Offline sidewinder427
« on: October 17, 2024, 08:28:43 AM »
Hi guys,
I have a question regarding the connection of the air ducts meeting the outer registers of the lower dashboard. The assembly manual says I need some "S-Clips" but mine are missing . Does someone have a photo how they look like and/or a source where I can get them?
Thanks for your help!
Andre
Re: 69 A/C air duct clips
« Reply #1 on: October 17, 2024, 04:28:10 PM »
Andre,
What is the manual name and number, what is the page number in the manual, and what is the part number you seek.
Offline AJ
« Reply #2 on: October 17, 2024, 05:35:26 PM »
See pics.  Sort of s S clip with an integral barb to secure the plastic duct.
Adrian Jacobs
70 Boss 302  Dearborn, 11/22/69, original calypso paint,  original family ownership.
70 GT500 , 02/26/69, a/c auto, candy red
« Reply #3 on: October 17, 2024, 07:02:34 PM »
Andre,
That's a picture of the clip but without the manual you looked at, and without a Ford part number, I have no place to start.
« Reply #4 on: October 17, 2024, 08:28:09 PM »
I looked at the assembly manual, page E9-695-11, which has a view discussing the "attachment of clip" but no part number is called out.  This leads me to believe that the clip was part of the more complex assembly.  It does not mean that the clip does not have a part number, most assuredly it does.  However, at the end of the day it was not handled here as a separate identifiable part on the assembly drawing.  What is interesting is that the center rectangular vent does call out the clips for that part.  Some days you get the elevator...
I also looked in the MPC illustration, and nothing there.  At the end of the parts listings in the MPC it is not uncommon to see a list of related fasteners.  Not so in this case.
Then I went to Jim's spreadsheet and filtered on "AIR COND" in the Location-Application column, and "CLIP" in the Description column.  Of the 5 records I see 383116-S which has a Location-Application of "AIR COND DUCT, RH/LH-PLENUM".  Data sources E9-695-7 and E0-695-7.  I'm assuming that data source E9 is the Electrical assembly manual for 1969, sheet 695-7.  Sure enough, that is what it is.  Mind meld alert.  My version of this page is very challenging to read.  Upon further review, this is NOT the part - see attachment.  The 383116 is for the plastic ductwork.
I tried.
« Last Edit: October 17, 2024, 08:30:19 PM by 67gta289 »
« Reply #5 on: October 18, 2024, 07:55:39 AM »
I'm pretty sure it was the Electrical Assembly Manual but I will check it tonight (also if there is a number).
AJ hit the nail, these are exactly what I mean. I believe I have seen one of these on the top ridge of the center register. But where to buy...??
I?ll check again later...
Andre
« Last Edit: October 18, 2024, 03:22:17 PM by sidewinder427 »
« Reply #6 on: October 18, 2024, 03:25:08 PM »
I've checked my manuals: The drawing with the description "S-Clip" is in the shop manual. No part no. though.... ::)
« Reply #7 on: October 18, 2024, 04:13:55 PM »
There are a couple of other possibilities:
From the 1975 Ford Car Parts, Text Section 190, pg 12 (also ref pg 13);
1. The service stock numbers, C9ZZ-19B680-B and -C, Ducts, are supplied with attaching parts - the "Clips", although there is usually a statement stating that;
2. The service stock numbers, C9ZZ-19B680-B and -C, Ducts, no longer need the "Clips" (a redesign?), so they are not shown;
Try to attach the hoses without the clips.
If you feel you need the clips, your only option is a donor car.
« Reply #8 on: October 18, 2024, 09:39:45 PM »
Have seen wide clear tape.
Offline 9F94M567042
« Reply #9 on: October 25, 2024, 02:59:34 AM »
Hi, I don't frequent this forum much, but I came across this post and thought I would look into it.
I have a 1969 Mercury Cougar built in Dearborn maybe even on the same assembly line!
I looked today at the AC duct clips on a spare lower dash I have. Pulled one of them off and got out my Standard & Utility Parts Catalog (dated Feb '98) but is fairly extensive.
Upon searching thru the various clip images, I came across what I believe is the clip you are seeking. It is also listed as a Non-Standard part, so finding it anywhere might be difficult.
I have attached some pictures of it as well as the catalog information about including size and part number.
Maybe this will help
« Reply #10 on: October 25, 2024, 11:05:35 PM »
Thanks for visiting and helping out as for you comment.
Since his signature  lists his 70 Boss as a Dearborn car yes both cars would have been built on the same line in the big car plant only likely on different days or months
Offline sah62
« Reply #11 on: October 26, 2024, 08:36:28 AM »
Check with Classic Auto Air and Old Air Products. They may have the clips if you can't find them anywhere else.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
« Reply #12 on: October 26, 2024, 04:37:54 PM »
Of the 5 records I see 383116-S which has a Location-Application of "AIR COND DUCT, RH/LH-PLENUM".  Data sources E9-695-7 and E0-695-7 (Mustang Electrical Assembly Manuals).
This Ford hardware part number is listed as shown above, 383116-S.
Quote from: 9F94M567042
The one you reference is Ford Hardware part number 374825-S3. I find no instance of its use in any 64 thru 73 Mustangs. It is not listed in any of the several aftermarket documents I have. I'm not saying it's correct or not, just pointing that out its use is "vague".
However, it is a starting point.
« Last Edit: October 27, 2024, 04:58:31 PM by jwc66k »
« Reply #13 on: October 27, 2024, 05:03:27 PM »
I found some additional "similar" items (see below, "Type 13" - 3 Ford hardware numbers listed, none used on Mustangs). Without actual photographs, including a reference measuring device, there is no real way to identify what this is.
« Reply #14 on: November 11, 2024, 08:17:41 AM »
Thanks guys, I was lucky to find some of a donor car...
Andre
