Author Topic: WTB Stock Valve Covers 1964.5 260CID engine  (Read 725 times)
Offline Corey Bowcutt
« on: January 28, 2025, 04:03:07 PM »
I am looking for a set of stock valve covers for my 1964.5 Convertible with a 260 engine.
Corey
Re: WTB Stock Valve Covers 1964.5 260CID engine
« Reply #1 on: January 28, 2025, 07:07:11 PM »
The type with PCV hole on RH side and filler neck on LH?  No notches on the bottom edge.
« Reply #2 on: January 28, 2025, 11:40:15 PM »
That is correct about the PCV and filler. I am not sure what the notches refer to?
Corey
« Reply #3 on: January 29, 2025, 01:26:46 AM »
The 64.5-65 covers are smooth on the bottom edge lip that is closest to outside of cylinder head.  In '66 there were notches added for clearance of smog tubes if equipped.  The bolt holes are in different locations on that bottom edge also.  I might have a pair, will see if I can find some in the next couple days.
The bottom edge detail has been discussed here previously.  One thread here doing a quick search:  https://www.concoursmustang.com/forum/index.php?topic=29057.msg179528#msg179528
« Reply #4 on: January 29, 2025, 07:47:01 AM »
Thank you Charles.  Very helpful!
Let me know of you find a set.
Corey Bowcutt
Offline OldGuy
« Reply #5 on: January 29, 2025, 09:22:20 AM »
Corey, if Charles doesn't have a set of covers, I do.
Frank
« Reply #6 on: January 29, 2025, 01:36:17 PM »
Thank you frank and Charley.  There is a gentleman sending me a set for free.  If it for some reason falls thru or they come and are not correct I will reach back out to you guys.
Much appreciated.
Corey
