First welcome to the site. Hope you find the information and support you need for your concours restoration projects
Hello,
I have a 1968 May Metchun Candy Apple Red Convertible. I have looked at discussions on Rear axle housing paint and other people seem to be painting it black. My car is pretty original, and I am just about sure the housing was not originally black.
Remember that the rearend assemblies were not assembled nor painted at the car plants but all in 68 at Sterling plant so the finishes would be identical for the same size and application no matter where the car was built
Also, Not sure if I should do another post about this but here it is.
I read that for non-undercoated cars with red oxide paint "(Paint drips should be visible" does anyone have pics on how they did this? I am going to be using rattle cans for this part of the job so that should be easy.
Thank you very much,
Nicecar
Since your new I guess you may have not found the unrestored picture thread section which will provide you with a fair number of pictures of unrestored cars for you to examine and consider. Also since we've been open for many years now there is a ton of earlier threads related to undercarriage paints and finishes used on our cars. Like all search features they are not perfect and will take a number of tries (different words and combinations) to find most of the threads
In response - there was no undercoating applied at any of the car plants. Some (pre 68 for Mustangs) there was no sound deadener applied at the car plants for special models like the Mach I, Grande and so on. Don't know of any rattle cans which will apply the darker, often fair shinny, epoxy primer sealer finish originally applied to the front end and the firewall rearward at the factory. The flat, red oxide Rustoleum will not correct and also consider you'll need to be adding body color overspray and then pinch weld black out on the rocker panels extending inward towards the drive shaft tunnel. Won't go any further on the subject since you already started the thread on another subject and don't want to create a lot of cross talk.
One picture from a low mileage 68 NJ built car showing the "red oxide" color primer sealer and the amount of shine it can have when there is no or little overspray or dirt on the panels . If you want to discuss this subject more I ask you to start a new thread in the 68 section or add to the earlier one on the subject
