Author Topic: 1967 Metuchen under body paint/detail procedure  (Read 131 times)
Offline 67429Merc
« on: May 13, 2025, 09:58:37 AM »
I'm sure this an old subject that has been posted many times! Yet I can't seem to find it. Will somebody please post a link? Thank you!
Re: 1967 Metuchen under body paint/detail procedure
« Reply #1 on: May 13, 2025, 03:17:37 PM »
Out of curiosity, I did a search and found nothing exactly matching your topic request, but I did come up with over 20 "general" under body paint topics. I didn't include pictures of unrestored. I would recommend reviewing the 67 Mustang Body Assembly Manual (AM0016) to see what Ford Engineering designed and what the assembly lines were "required" to do. Of course, "reality" vs "required" are often different.
« Reply #2 on: May 13, 2025, 03:32:39 PM »
First welcome to the site. Hope you find the support and information you need for your restoration related projects.
Since 67 NJ Mustangs are not as often restored as some other years and plants I've not written a specific article for those cars. Will look to see if I've gotten something started or we might just need to start fresh. Some of the details will be the same or similar to other plants that year. Well see what I can find.
In the mean time see what the search will turn up and also provide, if you would, when your car was built at Metuchen? SO that we can look at cars from the same period if possible. Will be moving this thread to the 67 section since it focuses on a specific year rather than paint and body work threads that span multiple years  ;)
Offline Coralsnake
« Reply #3 on: May 13, 2025, 07:53:48 PM »
This is for 1968, but it might help a little.
The primer was still the brownish red oxide
http://www.thecoralsnake.com/PAINT.html
« Reply #4 on: May 13, 2025, 08:48:47 PM »
Let's see if we can somewhat quickly offer something while we wait to see when the car was built. That will maybe help focus to a production period so we can offer some additional focus on the color and tint of the undercarriage primer sealer that was used
As you hopefully aware of by now the Library has in it currently, six articles that focus on basics related to body coatings and undercarriage painting.
Steps are as follows for a 67 Metuchen built car? the unibody of the car was prepped with the doors, trunk lid, front fender rear attaching brackets at A pillars, rear bumper guard brackets and the rear valance in place (valance hung from the taillight panel only by all the mounting screws). Other painted individual parts were painted on another line near by from the same pint source as the car.
1- The exterior of the unibody was coated with a read oxide primer followed by a light gray primer primer to fill the minor flaws like pen holes. Before and after these step certain gaps, seams and areas were sealed with sealant ans in other areas a coat of sound deadener was applied to surfaces. Since we are focusing on the undercarriage  we will not go into those details in this article at this time.
2- The undercarriage from firewall rearward was coated with an epoxy primer similar in color to a red oxide primer though since it was an epoxy based sealant it has a smooth and somewhat shinny final surface. At other plants this coat was applied by spray jets mounted below the moving tracks that held and guided the unibody during this part of construction. Since they didn't want overspray to rain down on the following car the jets were set to stop before the rear of the car was reached so it is not uncommon to find little undercarriage paint in the forward facing pockets of the rear frame rail, the bottom surface of it. And one of the reasons that cross member was galvanized coating.
3- The undercarriage section forward of the firewall (frame rails and lower inner fender panels for example) were then coated by hand with red oxide colored epoxy primer like the rear section. The source for this paint/coating may have bee different from the rear application so the tint can be visually different or very close to one another.
4- During these stations interior color is applied the dash, the A pillars and the interior of the doors depending on interior code. There were some areas where after that paint dried black out paint was applied to eliminate the possibility of seeing body color in areas where Ford didn't want to have it visible or stand out in the finished product.
5- Exterior paint was applied to the unibody from about where the fire wall was to the rear of the car including the door jambs and trunk sections. Overspray and direct application was introduced into the interior section of the car during this process. Prior to this step the rear wheel wells received a nice typically good coating of sound deadener. This was likely done at the same station where the sound deadener was applied to the trunk area of the car.
6- Exterior color was applied with some over spray flowing onto the undercarriage. The further a part of the pan hung down the more overspray it received. Can be a little or allot but never the whole floor pan. In the rear wheel wells the area received a nice coat of paint in most cases and over spray/ nice coat often found its way onto the exposed rear frame rail and sound deadener applied in the rear wheel wells that are visible from the wheel well and possibly further towards the middle of the undercarriage of the floor over the where the rear end housing would eventually be installed.
During the process of painting the exterior car fully body color was applied to the rocker panel pinch welds and because of the pressure and angle the paint coated panels that hung downward and faced out with paint and paint overspray was introduced to other panels in other areas that diminished as the floor goes toward the center of the car.
7- Next the semigloss black engine compartment paint is applied. Like the San Jose paint process the exterior sides of the inner fender panels were coated with the black paint from the forward facing panels at the rear of the front wheel wells where the splash shields would attach, all the way around to the other side of the car in the same area. This included the forward facing side of the radiator support and the #1 front cross member. As the drawings and pictures show on the wheel side the black would stop about the front edge of the sprung area. The area above the firewall pinch weld appears to have been blacked out on some models this year and plant. At the same time the area at the base of the windshield and a small area around the rear window vent hole was sprayed
8- Next the pinch weld was blacked out. The outer edge was a soft edge so many painted just back mask the line. The over spray from this application would again cover some of the undercarriage as it would naturally. Again the more part of the pan hung down the more paint/black out it received. The amount of overspray generally would be less the distance that the body color traveled as it was applied with less pressure and a single pass with the spray gun or jet was used.
9- At some point after all the painting seams on the under side of the car were seamed with a smooth thick black sealant in a applicator. The seams sealed included the center seat belt anchors and the rocker to floor seam where it was applied them spread with a kerosene soaked rag. For this plant and year it was typical to find them running the bead down the rocker then at the forward edge of the floor to rear spring front anchor section just to about where they turn towards the rear of the car unlike usually found done at other plants that year.
10- Once the rest of the body panels were installed and the car pretty much completely assembled the front wheel wells were coated over the inner fender panel, along the area of the fenders that meet the splash shields and up over the top of the fender. For this year and plant the coverage was pretty heavy and covered a good percentage of the panels
Please forgive any spelling or wording errors. This was created in the moment so expect it to have some. If you have any questions please ask. As I reread and others point out errors I will likely correct this post a number of times. This will help us flush out the descriptions and make the job of creating a full article easier. Will post some example picture over the next day or so. Hope this helps
You can find a few pictures showing some of the details above in the Unrestored Picture Thread section on the second page. Look for the one titled 67 New Jersey T Code Coupe - Unrestored Picture Thread
« Last Edit: May 13, 2025, 09:17:17 PM by J_Speegle »
