Author Topic: ? Cowl to Hood seal Brackets  (Read 5895 times)
Offline YELLOWBOSS2
« on: November 27, 2009, 10:03:45 PM »
On a  May 65 SJ car should the metal brakets at the end of the cowl to hood seal be bent down over the screws? If they are, does anyone know of a good way to bend them down?
Dave
Re: ? Cowl to Hood seal Brackets
« Reply #1 on: November 27, 2009, 10:09:46 PM »
no. but the rubber is cut even with the bracket.
Offline Twilight65
  • Gold Level Subscriber
« Reply #2 on: November 27, 2009, 11:52:14 PM »
I didn't cut my rubber off even like carlite65 said, but here's a picture of my 65 Dearborn with original brackets and new rubber. I think its pretty much the same for a San Jose. Metal bracket kind of supports the rubber at ends no bending.
Dave
« Reply #3 on: November 28, 2009, 12:24:50 AM »
Hope this helps - all 66 San Jose
Looks to be about 1/16" - 1/8"
Offline YELLOWBOSS2
« Reply #4 on: November 28, 2009, 07:27:29 PM »
Thanks for the responses. I was very close to bending the brackets down.
Dave
Offline s2ms
    • 6S1757 Info
« Reply #5 on: April 15, 2024, 05:08:21 PM »
Reviving this related old thread instead of creating a new one...
Late March built SJ car, what is the proper finish for the brackets and screws?
My originals had been bent down. Thought they were trashed and needed replacing but today was able to remove and straighten them, found this "AS"(?) logo on the backside:
« Reply #6 on: April 15, 2024, 07:37:43 PM »
Most would say phosphate, but I have found some painted black on cars that hadn't ever been disassembled.
Offline s2ms
    • 6S1757 Info
« Reply #7 on: April 16, 2024, 01:20:33 AM »
Thanks Charles, mine appeared to have traces of black paint as well. Should have specified late March 66 built SJ car.
Original screws phosphate or natural?
« Reply #8 on: April 16, 2024, 03:12:04 AM »
Normally phosphate, but would check some of the unrestored cars from the same assembly plant/time here on the forum.
Offline s2ms
    • 6S1757 Info
« Reply #9 on: April 16, 2024, 05:10:26 PM »
Thanks!
« Reply #10 on: April 16, 2024, 11:18:03 PM »
Given that you have a later 66 car I would say they were P & O
Going to separate this discussion from the others since you asked about a different year  ;)
Just to keep things neat
« Reply #11 on: April 17, 2024, 12:38:39 AM »
Try Ford hardware Part number 357903-S2. It's used on 64 thru 66 Mustangs for the two end brackets, qty 4.
It documented in this forum's library under topic "Mustang Hardware Spreadsheets 64-66". There are two Excel Spreadsheets there, on by "application" the other by "part number".
https://www.concoursmustang.com/forum/index.php?topic=10788.0
« Reply #12 on: April 17, 2024, 02:09:25 AM »
Qty 4. Would it be 2?  Maybe just a typo or mistake  since there was two used per car
« Reply #13 on: April 17, 2024, 12:48:53 PM »
No and yes. Two "brackets" and four "screws" (unless you drop one or the other).
Offline s2ms
    • 6S1757 Info
« Reply #14 on: April 17, 2024, 04:50:44 PM »
After cleaning the original screws up with a wire wheel they are in fantastic shape. Just treated with gun bluing followed by Boeshield which worked perfect for this purpose.
Thanks for all the info and help!
