Author Topic: Throttle cable  (Read 6102 times)
Offline Stangly
  • Gold Level Subscriber
Throttle cable
« on: January 07, 2012, 12:26:17 AM »
Does anybody have a photo of the end of the throttle cable that bolts to the firewall.  Mine is broken and has been jury rigged.  I was hoping to form a new piece out of epoxy.  The assembly manual shows a picture but it's not real clear.
Thank you,
David,
69 Sports Roof 302 2V (numbers matching)
Dearborn (June build date) Acapulco Blue
68 Coupe J-Code
San Jose (June build date) Sea Foam Green
2001 V6 Laser Red
2015 GT Deep Impact Blue
Offline Andrew@MagMustangs
    • MagMustangs
Re: Throttle cable
« Reply #1 on: January 07, 2012, 01:17:58 AM »
1969 or 1970? They have different Mount Styles at the Fire Wall End. Here is a 70 Cable
Offline Stangly
Re: Throttle cable
« Reply #2 on: January 07, 2012, 10:56:23 AM »
69, do you have a photo.
68 Coupe J-Code
2001 V6 Laser Red
Re: Throttle cable
« Reply #3 on: January 07, 2012, 12:58:08 PM »
This link
http://www.cougarpartscatalog.com/c9zz-9a758-a.html
 shows the reproduction cable with the cable end (looks like a hammer head). There are actually two versions of the 1969 throttle cable, there are steel and plastic versions of the part that bolts to the firewall.
Offline Stangly
Re: Throttle cable
« Reply #4 on: January 07, 2012, 03:40:50 PM »
Thank you that photo will do, a little card board form and I should be in business.  This web site is pretty cool there is quite a bit of new old stock.
Thank you again,
David,
68 Coupe J-Code
2001 V6 Laser Red
Re: Throttle cable
« Reply #5 on: January 07, 2012, 03:55:11 PM »
Thank you again,
David,
David, I think the fix you describe is only a stop gap solution. I have seen this tried many times with limited success. I don't think it will be long lasting. If you want to devote the time and energy to just get you going that is one thing but if that is not the case i wouldn't wast the time. There are still many in junk yards etc. Cougars used them too and are a great source. Just some of my thoughts. A repro is available but am not sure how faithful it is to the original design.Bob
Offline rockhouse66
Re: Throttle cable
« Reply #6 on: January 07, 2012, 07:00:17 PM »
The repro has a black covering on it instead of the exposed twisted wire appearance and is not similar to the original in that regard.  Yes, they were used on lots of cars and should be in junkyards, but you will be lucky to find one that does not have a broken guide sleeve on the carb end.  They are fun to look for though and worth the effort!
'66 GT FB
Offline Stangly
Re: Throttle cable
« Reply #7 on: January 07, 2012, 10:14:01 PM »
I roughed up the remaining surface poured some epoxy.  It appeared to work pretty well, so I gave it the tweak test popped immediately, not enough to bond.  I will have to hit the junk yard and do some snooping on line.
Thanks guys,
68 Coupe J-Code
2001 V6 Laser Red
Re: Throttle cable
« Reply #8 on: January 08, 2012, 08:16:34 PM »
Repo and replacements also use the plastic firewall mount
Offline rockhouse66
Re: Throttle cable
« Reply #9 on: January 08, 2012, 09:01:35 PM »
Hi Jeff,
I don't know what the change/breakdown is on the steel versus plastic firewall mounts but I think both can be originals.  I am sure the plastic one that was on my car when I got it is original because it has firewall sound deadener on it.
'66 GT FB
Re: Throttle cable
« Reply #10 on: January 08, 2012, 10:23:07 PM »
Mentioned it case he was replacing a metal based one. I know I wasn't happy when I got the plastic sytle
We should likely start collecting reference VINs as wee if we can identify a pattern since more and more of them are being replaced.  Will look through my sources to see what I can offer
Offline rockhouse66
Re: Throttle cable
« Reply #11 on: January 09, 2012, 08:55:58 AM »
My original plastic one is on 9R02R156640 built 3/18/69 in San Jose.
'66 GT FB
Re: Throttle cable
« Reply #12 on: January 09, 2012, 09:24:55 PM »
Ok tool a look at my San Jose pictures from 69 Mustangs and found the following (of course allot of them did not include a good picture of that particular area :(
With metal attachment throttle cables
114855
120271
125360
131545
146511
148866
With plastic attachment throttle cables
104037 (guessing this one has been replaced since it falls outside the pattern by allot of time)
156440
156640 (yours)
157240
Not a big sample so far but the pattern did appear
Again for those viewing this is 69 SAN JOSE ONLY in this post ;)
Offline rockhouse66
Re: Throttle cable
« Reply #13 on: January 10, 2012, 09:33:22 AM »
Jeff - it would make sense that the plastic design is a late version, since the service replacements were also plastic.  Looks like maybe a Feb/March changeover at SJ?  Thanks for the research!
'66 GT FB
    • MagMustangs
Re: Throttle cable
« Reply #14 on: January 10, 2012, 02:50:19 PM »
That was my initial thought too, and it seems feasible. I wouldn't be surprised if the same happened at Dearborn and NJ also, although not necessarily at coinciding dates as existing supply would most likely be used up at each plant before the changeover. I have noticed a lot of changes around that period from Metal to Plastic, it seems the Ford bean counters decided that Plastic was more Economical to mold and produce than Metal. A lot of bits and pieces that were made of metal in 1969 were switched to plastic versions in 1970. Most of these would probably be introduced as running changes, instead of an exact Model Year Changeover. Just some thoughts to add to the discussion. :)
