Author Topic: Radiator Paint  (Read 16356 times)
Offline Sunlitgold68
Radiator Paint
« on: July 27, 2009, 10:36:04 AM »
What is the best paint to use when restoring a radiator? Looking at the satin finish radiator paint from eastwood. Would this be correct or is semi gloss better? thanks
8T01C204XXX
Built May 14th, 1968
Re: Radiator Paint
« Reply #1 on: July 27, 2009, 01:18:04 PM »
Semi-gloss black lacquer is what you need.  The Eastwood stuff works well for this application.
Offline dan green
Re: Radiator Paint
« Reply #2 on: July 29, 2009, 01:24:41 PM »
Be sure what you use is not an enamel or urethane, they don't transfer or dissapate heat well.
Offline C5ZZ
Re: Radiator Paint
« Reply #3 on: November 25, 2009, 10:23:38 PM »
I have heard both ways on this.
I have a customer that builds/recores radiators, they said it doesn't matter,
anyone have first hand experience with this?
MCA # 00945
Rangoon Red/Red Interior
Re: Radiator Paint
« Reply #4 on: November 26, 2009, 12:33:37 PM »
Depending how thick the paint is applied, it may or may not matter what type of paint is used.  Also, keeping the paint thin on the fins would also most likely make the biggest difference.
Re: Radiator Paint
« Reply #5 on: November 26, 2009, 10:48:13 PM »
I also like and use Eastwoods' radiator paint for this purpose. Takes a while to dry but happy with the results
Offline SCJSTU
Painting radiator help
« Reply #6 on: July 01, 2010, 10:42:22 PM »
what are you guys using?
I am having mine recored and they will leave it bare for me to paint...
thanks, Stuart
ps 1970 351C June 1970 build at Dearborn.......a/c car
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
Re: Painting radiator help
« Reply #7 on: July 01, 2010, 11:39:29 PM »
Any semi-gloss paint will work.  The main thing to remember is to not let the paint build up much on the fins.
Some say that lacquer is best for radiators as enamel-based paints act as an insulator.
Offline SCJSTU
« Reply #8 on: July 02, 2010, 12:14:40 AM »
Charles,
any concern with how hot the radiator gets for a long period of time?
Rustoleum or?
« Reply #9 on: July 02, 2010, 02:24:32 AM »
I'd use lacquer or a light coat of catalyzed acrylic enamel.
« Reply #10 on: July 02, 2010, 08:21:06 AM »
Eastwood makes a satin black radiator paint which is what I used, turned out nice.
http://www.eastwood.com/eastwood-radiator-black-paint.html
8T01C204XXX
« Reply #11 on: July 02, 2010, 09:35:05 PM »
+1   what I used on the last project
Offline macdude67
« Reply #12 on: July 11, 2010, 08:10:49 PM »
I'll third the response for the eastwood semi gloss radiator paint, I used it with great results.
Offline BillEBobb
« Reply #13 on: July 12, 2010, 08:48:48 AM »
Absolutely!  I think the finish looks correct, too.
Offline SCJSTU
« Reply #14 on: July 13, 2010, 07:32:17 AM »
thanks for the replies...
what are you using to clean the metal before painting?
