Author Topic: Choke tube into exhaust manifold, repro too large?  (Read 1964 times)
Offline Sunlitgold68
« on: May 09, 2012, 12:16:20 AM »
Helping a friend get his choke working and the reproduction choke tube that presses into the exhaust manifold is huge and looks impossible to fit into the small fitting at bottom. Any trick to this?
8T01C204XXX
Built May 14th, 1968
Online aaatp
Re: Choke tube into exhaust manifold, repro too large?
« Reply #1 on: May 09, 2012, 09:14:53 AM »
I would check to see if there are remnants of the old tube still in the hole.
« Reply #2 on: May 09, 2012, 09:18:30 AM »
Might have to drill it out.  Be sure to use an air blower and vacuum to get the shavings out.  Otherwise they'll end up inside your choke chamber on the carb.
« Reply #3 on: May 09, 2012, 12:35:25 PM »
As others have indicated it is all to often that a tube is snapped off at the base giving the indication that the hole is smaller then it really is . It drills out realitively easily just watch the shavings as Charles posted.
Offline JohnRB
  • 0F03R120303
