Author Topic: Underlayment  (Read 2108 times)
Offline cobraboy
Underlayment
« on: September 01, 2012, 02:43:16 PM »
Hi Guys
About a month or so ago I posed the question as to where to obtain correct underlayment for my car.
Ssnakeoyl came up and I ordered a set.
I picked it up today from my shipper and had a look.
I have taken a pic of the original uner rear seat piece to show you. This is a 1/8" thick piece of stiff tarry card like material with a dimpled underside.
The new stuff is a tarry paper with a thin cotton jute underside and is very floppy.
Is this the best you can get now ?, it is nothing like what was originaly fitted.
The front pieces in the car are very bitty so I will have a job finding the original shape.
I was thinking of soaking some thick plain card I have in old engine oil then letting dry out. This would replicate the original stuff quite well in substance and colour.
Or have I just bought the wrong stuff and there is better available ?
Thanks in advance for your thoughts
Mark.
Old  and new
Underside of old
Edge of old
Edge of new
Underside of new
13th April 1965 Dearborn K GT on the other side of the pond.
Offline NEFaurora
Re: Underlayment
« Reply #1 on: September 01, 2012, 03:07:33 PM »
There were different supplier of underlayment to Ford.  Believe that not all cars had the cardboard underlayment like your car.
The top of the Snake Oyl does look like original '65-'66 underlayment and is floppy like original.  I have a problem with the jute backing as I do not believe the original had any type of jute backing.  The cut looks like it could definately be improved.
Welcome to the wonderul world of reproduction parts!
MCA#70001
Offline ChrisV289
Re: Underlayment
« Reply #2 on: September 01, 2012, 05:01:07 PM »
Mark,
I have ran into the same problem as well..I had the same underlayment on my back seat and got the same material from Snake Oyl...Anyone else tried any other supplier?
2009 V6 Mustang Coupe
Re: Underlayment
« Reply #3 on: September 02, 2012, 02:54:55 AM »
Unfortunately, the Ssnake-Oyl stuff is the best you're going to find, unless you endeavor to reproduce it on your own, which could be very time-consuming and mixed results.
Offline cobraboy
Re: Underlayment
« Reply #4 on: September 02, 2012, 04:18:30 AM »
Thanks all.
I am going to have a go at making some, I will let you know the results.
Mark
Re: Underlayment
« Reply #5 on: September 04, 2012, 07:54:25 PM »
Depends on the time period and plant on these early cars from what I've seen. The later tar/jute/tar versions had different final outer layers depending on suppliers but as mentioned much later
And as Charles mentioned you have limited choices that will arrive in the mail from current suppliers. Other choices are donor cars from the same period or making stuff yourself
Offline cobraboy
Re: Underlayment
« Reply #6 on: September 07, 2012, 04:26:13 PM »
Thanks Jeff
Not too many Mustang boneyards here, will be making some - a winter project.
Mark
