Author Topic: 68 Exhaust Manifolds ?  (Read 2336 times)
Offline Brian Conway
« on: September 17, 2012, 11:10:26 PM »
Looking around for the correct exhaust manifolds for a restoration project.  Would like some help with the correct engineering numbers and an approximation of correct dates.  The car is a 1968, San Jose Mustang Fastback  390-4V, 4 speed w/ GT Equipment Group.   Marti Build date is 3/18/68.
           8R02S   63B  Y5  6A  12C  71  E  S
EBay has a set:  Left    C7OE-9431 A  and 8  B  7
                           Right  C6OE 9430 A  and 8  B  10
I don't have the block casting date.  Are the C7OE and C6OE correct for this time frame ?  Thanks,  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Re: 68 Exhaust Manifolds ?
« Reply #1 on: September 17, 2012, 11:53:31 PM »
The casting numbers are fine - they kept using them until there was a revision - (then new numbers or letter was changed)
The dates, from the few I have records of are normally 3-5 months before the cars final date
Offline TLea
« Reply #2 on: September 18, 2012, 08:54:10 AM »
+1  The dates are pushing it as too close. I had a 68 FE build of 1/19 with exhaust dates of 1/5 and 1/6 and thats as close as I've seen
« Reply #3 on: September 18, 2012, 10:30:35 PM »
So would   7  M  14&16  be a fit ?  Is this exhaust manifold supposed to use a spacer ?  Thanks,  Brian
« Last Edit: September 18, 2012, 10:34:01 PM by Brian Conway »
San Diego, Ca.
« Reply #4 on: September 18, 2012, 10:41:35 PM »
Ford made a change on the RH 390/428 manifold between 67 & 69 on the h-pipe spacer end & can be seen on top side when installed in car & mpc says date change when i looked it up.
« Reply #5 on: September 18, 2012, 11:30:45 PM »
Based on the dates I'm seeing - yes, solely based on the cars projected build date (you need to get a Marti ;)  not the other engine parts dates
« Reply #6 on: September 19, 2012, 11:16:22 AM »
Thanks for taking an interest.  I have a Marti Report and the ' Actually Built ' date is 3/18/68.  Brian
San Diego, Ca.
« Reply #7 on: September 19, 2012, 11:08:16 PM »
Without interest in each others projects and questions - we would not have a site ;)
Pretty close to the projected (best guess) date they made earlier it appears.
