Author Topic: Item ID  (Read 5523 times)
Offline hkopp
Item ID
« on: January 04, 2013, 02:00:00 PM »
This was in a pile of parts in a dismantled 69 grande.  Looks like a throttle cable bracket, but not the same as the one on my 69 428 or 70 cars.  Is this even a mustang part?
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1965 Mustang 347, 5 spd, 1st car!
1967 Camaro SS350 all #'s
1967 S code
1969 Mach 1 428SCJ-R #'s
1969 Mach 1 428CJ-Q Auto
1969 Mustang Grande, 650hp, 2nd car!
1970 Mustang
1970 Mach 1 351C
1975 Ford F250, 44s, 21" lift, 3rd car!
2002 Avalanche
2011 Vette
Re: Item ID
« Reply #1 on: January 04, 2013, 08:45:09 PM »
Index bracket for the power steering pump
Keeps the high pressure hoses correction orientated to the rest of the parts- exhaust, pump case ....
Next step would be to identify what it came off of - would guess there are 50+ of different shapes and car applications. If I recall correctly no part/engineering  numbers to help with the search
Offline hkopp
Re: Item ID
« Reply #2 on: January 05, 2013, 12:28:34 AM »
Thanks Jeff...do you think it was from this grande?
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1967 S code
1970 Mustang
1970 Mach 1 351C
2002 Avalanche
2011 Vette
Re: Item ID
« Reply #3 on: January 05, 2013, 02:01:38 AM »
..............do you think it was from this grande?
Well there is no information about the Grande (or any other car) in your signature or this thread so no way of telling :(
IF if happens to be a 351 Windsor from 69 then I think we have a winner
an example of said ps hose index bracket
Offline hkopp
Re: Item ID
« Reply #4 on: January 05, 2013, 11:29:55 AM »
Amazing.  I dont know how you do it Jeff....spot on.  Its a 351 car.  So one final question...where does it bolt onto?
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1967 S code
1970 Mustang
1970 Mach 1 351C
2002 Avalanche
2011 Vette
Re: Item ID
« Reply #5 on: January 05, 2013, 05:24:26 PM »
............. Its a 351 car.  So one final question...where does it bolt onto?
This should help
Offline hkopp
Re: Item ID
« Reply #6 on: January 05, 2013, 05:54:13 PM »
Perfect!  With the square knockout I was a little confused where it was supposed to go.  Thanks!  (I finally updated my profile too...thanks for the nudge.  ;) )
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1967 S code
1970 Mustang
1970 Mach 1 351C
2002 Avalanche
2011 Vette
Offline hkopp
Re: Item ID
« Reply #7 on: January 08, 2013, 11:56:18 AM »
I really need to brush up on part interchange as I tried to install the bracket and learned that I had restored a 1970 unit, with the offset and larger pressure line.  And it also uses the steel bracket rather than the aluminum.  Sigh.  1969 parts coming...anyone know if the 1970 pump and flat steel bracket are worth much?  They are rebuilt and restored...curious before I list them for sale.  Its the D0OR-B pulley, 70 pump, and 70 adjusting bracket.
Oh well...more practice on rebuilding and painting pumps.  :)
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1967 S code
1970 Mustang
1970 Mach 1 351C
2002 Avalanche
2011 Vette
Re: Item ID
« Reply #8 on: January 08, 2013, 03:47:39 PM »
Not sure what your using for a reference (generic wrecking yard interchange will not do) but the picture I posted of the full pump and bracket are from a 69 351 Windsor - aluminum carrier (steel front adjusting bracket, correct offset and other details if your looking to compare something to what you have or need
Offline hkopp
Re: Item ID
« Reply #9 on: January 08, 2013, 04:40:43 PM »
I was going off of memory, thats the problem...that and anxious mustang dismantler's that told me the parts were 69 351 parts....I knew the pulley wasnt but thought, hey...its a 351w and a lot of 69/70 stuff interchange.  sigh.  I am not going to numbers on this car (thankfully) as I spent 11 years chasing date codes for my 428scj car.
I picked up the 69 parts last night using your photo to confirm...looking forward to them arriving - then rebuilding and painting another one!  :)
Thanks Jeff!
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1967 S code
1970 Mustang
1970 Mach 1 351C
2002 Avalanche
2011 Vette
