Author Topic: 67 8" differential marking  (Read 3096 times)
« on: March 05, 2013, 08:28:39 PM »
Took the differential out of the axle this evening and started the cleaning process.   The car was put on a ramp, sandblasted, and primed in 1980, which explains the red oxide on the lower half of the differential and some of the bolts.   The upper half of the axle retains a different color red oxide, along with what might be an "11" or "H" in yellow marking.  Any comments would be appreciated. Hopefully I can find more.  This is an automatic with 2:79 axle.  Thanks John
Re: 67 8" differential marking
« Reply #1 on: March 05, 2013, 09:27:40 PM »
Thanks for sharing - shame that some one rattle canned red oxide over all the original stuff but can't change that now ;)
IMHO I would think that the mark, given the year, model and location of the mark) is a number likely related to the assembler or inspector. That would better match the pattern I've seen
« Reply #2 on: March 05, 2013, 10:51:52 PM »
Check your casting date on that pumpkin. It looks like it is from 1964?
As far as I know, by 1967 they should have the ribbing? May or may not have the fill plug, early 1967 8 inch housings had a fill plug in the back of the housing.
« Reply #3 on: March 06, 2013, 01:27:32 PM »
Good catch Scott (forest from the tree  and all that ;)
« Reply #4 on: March 06, 2013, 05:41:30 PM »
Thanks for the info, I had no idea.  Now I have something new to put on my shopping list.  Am I looking for something like the picture below, with appropriate dates of course?
My axle housing does have the fill plug.  Does that mean that the proper differential should NOT have one, or would there be two?
Offline tomtri66
  • Bronze Level Subscriber
« Reply #5 on: March 06, 2013, 06:55:45 PM »
Related to the 1964 carrier, I found a "3" in the area of your "11" or "H" marking on a Jan 27, 1965 casting date carrier (don't know the assembly date tag was missing).  I have seen pictures of "1" and "2" s in the same area in my internet searches.  Makes sense that they are assembler or inspector numbers as Jeff says.  Also found an "8" on the lower driver's side of the carrier.  I have seen this on other carriers as well.  It seems logical that this is a quick way to identify the rear as an 8 inch variety.  Also found an "8" written on the inside of the axle housing which I assume is for the same quick ID.
Good luck in your search for the correct '67 carrier.
Tom
MCA# 78748 Adirondack Shelby Mustang Club
66 Metuchen HT Sprint 200 Package B
6T07T194XXX   65A       Y       22     20A     ?        2       6
                    BODY  COLOR  TRIM  DATE  DSO  AXLE  TRANS
C/O    762
4        A20     6T07T194XXX
65A       Y        22
« Reply #6 on: March 07, 2013, 12:11:23 AM »
Here is a San Jose unrestored 67.
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #7 on: March 07, 2013, 08:08:53 AM »
I am taking out my 68 one and putting it's gears/bearings/pinion-carrier into the 66 casting I have acquired.
You are welcome to the 68 casting after I change-over if you are interested.
Here's the one coming out.
Here's the one that's going in.
« Last Edit: March 07, 2013, 08:17:30 AM by bryancobb »
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #8 on: March 10, 2013, 06:28:07 PM »
Thanks for the offer Bryan, but at this point I'll start the hunt for a date correct one.  After all, they only made hundreds of thousands of em.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #9 on: March 10, 2013, 09:48:25 PM »
This one is 7A7.  I thought it was a 68 but it is a 67.
I think 7A7  is JAN 7, 1967?
66 Metuch Conv
« Reply #10 on: March 10, 2013, 09:59:12 PM »
