Author Topic: Mexican Block Sizes  (Read 7625 times)
Offline ceswert
  • Silver Level Subscriber
Mexican Block Sizes
« on: March 08, 2013, 11:53:07 AM »
Did Ford use Mexican made blocks for 289 Hipo engines?
67' Shelby GT 350 nm blue/4sp/#0089
07' Shelby Super Snake 725hp/white/#0073
71' Mach 1 429cj grabber blue/4 sp./ac
Re: Mexican Block Sizes
« Reply #1 on: March 08, 2013, 12:24:29 PM »
No.
Offline ceswert
« Reply #2 on: March 08, 2013, 09:34:27 PM »
What engine size(s) were built using Mexican blocks?
« Reply #3 on: March 08, 2013, 11:28:22 PM »
Think they were 302 cu. Popular for a time  with the open track guys (weekend road racers ;).
BTW don't be talked into using Mexican main caps on a US block- the us and Mex main caps are different  though they will work.
Offline ceswert
« Reply #4 on: March 09, 2013, 12:40:14 AM »
Thanks Jeff!
Offline cobrajetchris
« Reply #5 on: March 09, 2013, 04:23:03 PM »
I always heard that some of the 69 302 blocks made in Mexico are better than the U.S built one. What is the difference and how do you identify one from the other? Anyone know the time frame FORD used this plant?
CHRIS KNOBBE
69 MUSTANG COUPE, DEARBORN BUILT 06/10/69 OWNED SINCE 1978
70 BOSS 302 MUSTANG, DEARBORN BUILT 10/24/69 OWNED SINCE 1987
69 R CODE MACH1 AUTO, DEARBORN BUILT 10/10/68 OWNED SINCE 2006
69 R CODE MACH1 4 SPEED (factory black) SAN JOSE BUILT 12/30/68 OWNED SINCE 2007
« Reply #6 on: March 09, 2013, 06:10:39 PM »
Yes the Mexican 302 was more HD than the regular 302 built (little thicker walls if I recall correctly and the bigger hipo style main caps) in the US but not when compared to the Boss 302
If I remember the valley casting and markings as well as the front the front exterior casting. Easy to notice the differences when someone tries to slip one in a car and tries to pass it off as a regular small block ;)
Sorry no pictures in my files since they didn't come in any of of the US built Mustangs though have seen tons of them at swap meets and wrecking yards over the years.
The mexican plant?  Not sure when it opened but they built Mustangs through 65-69 at least if I recall correctly.  Though I believe that some of the sheet metal was shipped from the US for the build but often countries set up percentage of what has to be from their country and what can cam from outside. No aware of any US built vehicles that used mexican V8 block's back in the 60's for their original engines
 The plants in South America were around for a number of decades (see below)  not sure what those V8 blocks look like if they even cast those there or made a V8 car. Venezuela plant was opened in 62 till today, and there was one in Argentina - guys use to go down there an buy up allot of model A and early V8 sheet metal in the 70's and 80's.
Also found (not sure what periods they operated) additional mexican plants that are now closed
Cuautitlán Engine  in     Cuautitln, Izcalli Mexico
Cuautitln Tool and die in Cuautitln, Izcalli Mexico
La Villa Assembly in La Villa, Mexico (closed in 84)
Information taken from http://en.wikipedia.org/wiki/List_of_Ford_factories
« Last Edit: March 09, 2013, 06:33:02 PM by J_Speegle »
« Reply #7 on: March 09, 2013, 06:19:35 PM »
Some pictures from a posted add
« Reply #8 on: March 10, 2013, 01:33:13 AM »
Informative, thank you...
CHRIS KNOBBE
Offline Stangly
  • Gold Level Subscriber
« Reply #9 on: March 10, 2013, 11:38:18 PM »
Jeff,
My Dearborn built fastback has a mexican block (numbers matching)  I will post some photos.  I found it strange how it would have made it's way to Michigan.  Did I understand correctly you said these typically were not in US made cars.
David,
69 Sports Roof 302 2V (numbers matching)
Dearborn (June build date) Acapulco Blue
68 Coupe J-Code
San Jose (June build date) Sea Foam Green
2001 V6 Laser Red
2015 GT Deep Impact Blue
« Reply #10 on: March 11, 2013, 02:13:53 AM »
Jeff,
David,
Yours would be the first I've heard of - will be interested in the casting and assembly dates - ;)
IF the casting dates don't line up maybe its a service/warranty  replacement - since those often had the car's VIN added. Will wait and see what you report back with
« Last Edit: March 11, 2013, 05:03:06 AM by J_Speegle »
Offline Stangly
« Reply #11 on: March 12, 2013, 10:15:46 PM »
Here are some photos Jeff, I had to pull the starter, I couldn't read the date code in any of my photos from rebuilding.  I'm not sure how to read this date code it doesn't show up in my Mannel book anywhere.  The date code is 23J8 kind of hard to read with the flash.
68 Coupe J-Code
2001 V6 Laser Red
« Reply #12 on: March 12, 2013, 10:39:32 PM »
Looks like it was cast about 9 months prior to your car being built.  - Sept 23  68
Can you make out the assembly date through the paint (small block extension just in front of the drivers side head)?
Thanks for the effort
Offline Stangly
« Reply #13 on: March 13, 2013, 12:12:40 AM »
I put a piece of paper on it and rub with a pencil, looks the first three digits is all I can make out.
9F2 hope this is enough.  I looked at some pictures of the rebuild and can clearly see the first two digits are 9F, I could hit the paint with a little steel wool if need be.
68 Coupe J-Code
2001 V6 Laser Red
« Reply #14 on: March 13, 2013, 11:17:41 PM »
That should do - indicates the engine was assembled June 2nd 69
Looks like it fits the picture and you might have the only Mexican block I've seen in a classic US built Mustang. Thanks for sharing
