Author Topic: reproduction wiring harness  (Read 2540 times)
Offline rocnhrse
« on: March 16, 2013, 11:56:33 AM »
what is the general feeling of reproduction wiring harness are some brands better than others
67 s code non tach gta built april in San Jose
67 mustang  GTA  S code fastback  San Jose  April 67
Re: reproduction wiring harness
« Reply #1 on: March 16, 2013, 11:58:01 AM »
i have had good luck with the ones from alloy metal products. these are sold by npd & va classic mustang.
Offline Oz390
« Reply #2 on: March 16, 2013, 02:24:06 PM »
+1 on Alloy Metal.  While not 100% exact, they are very, very, very close and have never had a fit problem.  And they match the OEM wiring diagrams, as some others do not...
8R03S : 76A I 2A 15M 72 5 U
Offline rocnhrse
« Reply #3 on: March 16, 2013, 07:30:01 PM »
thanks for your input I will heed the advice,there will be lots more questions as I
restore this mustang
Offline Stangly
  • Gold Level Subscriber
« Reply #4 on: March 16, 2013, 11:43:00 PM »
If you have anything of your harness left check out Randy at Midlife Harness restoration.  He is a great guy and knows the wiring inside and out.
69 Sports Roof 302 2V (numbers matching)
Dearborn (June build date) Acapulco Blue
68 Coupe J-Code
San Jose (June build date) Sea Foam Green
2001 V6 Laser Red
2015 GT Deep Impact Blue
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
« Reply #5 on: March 19, 2013, 12:01:59 AM »
If you get a under dash harness, do your self a favor and do check that they put the wires into the correct slots before you plug them into each other.  I found four miss placed in one from alloy. Don't get me wrong it is the better product, but it could be a disaster.
MCA#31064
« Reply #6 on: March 19, 2013, 02:25:13 AM »
Yes double check - had a similar situation - a few miss matched l-plug in's at the firewall plug on a 69
« Reply #7 on: March 19, 2013, 07:39:06 AM »
The current crop of 1969 headlight harnesses from Metal Alloy have a flaw in the wire colors.  This repro harness does not come with the firewall plug, so you have to re-use it, and there are decent instructions for where to put the wires.  Anyway, the harness comes with two green/black wires: one for high beams and the other for the washer pump, but they are not distinguishable.  The instructions states that the washer pump wire is light green/black, but it is identical to the high beam wire.
In the past 3 months, I've had to re-pin 3 of the repro headlight harnesses for international customers.
Sorry for mixing up years, but wanted to post that Metal Alloy's quality control has been slipping ever so slightly, so it is important to double-check everything before hooking up the battery.
« Last Edit: March 19, 2013, 07:40:56 AM by midlife »
