Author Topic: Dimmer Switch Rubber Pad?  (Read 5166 times)
Offline Skyway65
  • Gold Level Subscriber
« on: April 19, 2013, 08:33:53 PM »
Does anyone know if any model or year ever had a rubber pad on the dimmer switch from the factory?  I have never seen one on any of the '65 or '66 Mustangs I've had over the years although I do recall a friend had a '67 coupe many years ago that did have the black pad.  Comments or observations please.
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: Dimmer Switch Rubber Pad?
« Reply #1 on: April 19, 2013, 09:51:36 PM »
I'm not 100% sure, but I believe they only came on convertibles.
« Reply #2 on: April 19, 2013, 10:15:27 PM »
Yes they did.  +1
Offline Skyway65
« Reply #3 on: April 20, 2013, 11:54:54 AM »
OK--but why only on convertibles?  In case you're driving in the rain with the top down they give you insulation from a possible 12V shock when you dim your lights?!  ;) :D
« Last Edit: April 20, 2013, 11:58:24 AM by Skyway65 »
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline mgmradio
« Reply #4 on: April 20, 2013, 12:21:32 PM »
My 65 convertible and one of my coupes have the pad. The one on the coupe is differen from the one on the convertible and I'm not 100% positive it is original even though the car has only 4,500 miles on it.
Formerly the MCA ANHJ 64.5-66!
Offline mgmradio
« Reply #5 on: April 20, 2013, 12:23:33 PM »
The reason for it on convertibles is because it is so close to the inner rocker. Gives you a better chance of hitting it.
« Reply #6 on: April 20, 2013, 12:24:38 PM »
I put the cap on all my cars, it looks better than a bare steel switch. I believe the plastic grommet that goes in the hole in the carpet around the switch is an "aftermarket only" item but I use them too.
« Reply #7 on: April 20, 2013, 03:43:53 PM »
Convertibles have inner rocker panels, position of the switch is higher up.
« Reply #8 on: April 20, 2013, 03:44:39 PM »
Yes, the plastic grommet wasn't used originally.  Always comes in the aftermarket carpet kits though.
« Reply #9 on: April 21, 2013, 02:13:06 AM »
Maybe in case it is raining or it is wet so your foot dosn't slip off the switch.
« Reply #10 on: April 21, 2013, 12:16:04 PM »
If you look up c5zz # for the dimmer rubber cap it calls out for convertible & that is only car I ever seen them on from factory..  I did study this trying to figure out why convertibles used it & determined it was location of dimmer switch. The convertible only innerrocker ties into touque box at bottom of kick panel & there is not much room for LH foot to find relocated dimmer switch especially on manual trans cars the clutch pedal pad gets in the way & having rubber cap on dimmer switch you can find it easier with your foot.   If you compare a coupe or fastback with 4-speed convertible in this area you will see what I mean.
Offline Skyway65
« Reply #11 on: April 23, 2013, 07:16:08 PM »
thanks for the input on this topic--I never would have figured that the location of the switch would necessitate a rubber cover!
Gary Schweitzer
MCA #00181
Traverse City, MI
