Author Topic: Four way flasher location  (Read 18287 times)
Offline MWM
« on: May 17, 2013, 03:51:11 AM »
When did the switch go from the drivers side to the passenger side?
Re: Four way flasher location
« Reply #1 on: May 17, 2013, 09:48:40 AM »
Are you asking about four way emergency flashers in '65 cars?
Offline MWM
« Reply #2 on: May 17, 2013, 12:25:32 PM »
Yes, please. For a 1965. Sorry I omitted that part.
Offline NEFaurora
« Reply #3 on: May 17, 2013, 08:04:14 PM »
Not to hijack a thread here, but since we are on the subject, I'd like to add 4-way flashers to my '65 Standard Convertible.  Outside of locating an original NOS kit off Ebay,  Does anyone have any suggestions???
Tony K.
MCA#70001
« Reply #4 on: May 17, 2013, 10:04:16 PM »
Tony K.
Although not concours-correct, you can add the early 66 e-flasher system to the main harness as a plug-n-play option.  The switch would go in the glove box.  Of about 10 e-flasher switches that have come in, not a single one still works, and it is not being reproduced.  I did find a reasonably close switch that has the proper functionality.  I also have at least 3 or 4 of those harnesses in stock.
Offline NEFaurora
MCA#70001
Offline NEFaurora
MCA#70001
Offline NEFaurora
« Reply #7 on: May 17, 2013, 11:07:18 PM »
Also, Getting to the very basis of this thread.. The original poster poses a great question(s)..
On Early to Late '65 Mustangs that were not equipped with the 4-way flashers, Where would the Dealers generally install them?  Under the dash??  Or in the glovebox like '66 cars???  Where were the Emergency Flasher switches installed on Factory installed cars???
Great questions!!
Tony K.
MCA#70001
Offline NEFaurora
« Reply #8 on: May 17, 2013, 11:11:46 PM »
Hey, I'm having a brainstorm here.. Also, Who carries the white clearish plastic "holder" that holds the flasher itself in the '66 cars that bolts in near the glovebox to hold the flasher..???
MCA#70001
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #9 on: May 17, 2013, 11:46:32 PM »
This is the 65 emergency flasher unit. As you can see you can take the 66 unit, take off the plate and use it. It will not be 100% but would be "more correct" then a 66 unit mounted in a glove box. Just an idea.
« Last Edit: May 22, 2013, 08:36:08 AM by 5F09CNot4Sale »
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline NEFaurora
« Reply #10 on: May 18, 2013, 06:24:09 AM »
Please do post the original instructions.  Also, It looks like the tip of the original switch is painted semi-flat black, or is that a Black rubber tip??
Do tell.
Tony K.
MCA#70001
« Reply #11 on: May 18, 2013, 08:27:58 AM »
Nice!  I've never seen the 65 version.  Both of the 66 reproductions will work just fine, but my prices are a bit better!
Offline C5ZZ
« Reply #12 on: May 18, 2013, 09:39:53 PM »
I have the flasher accessory for my 65, I found the hole to use
that was already in the dash in front of the fresh air vent, it has
a flat in the hole that matches up with the flat on the switch.
My dash is from a 9/64 Dearborn build so the flasher accessory
was either available then or they had planned on it early on.
MCA # 00945
65 Fastback, 6 cyl, AT, AC, PS, PB
Rangoon Red/Red Interior
Offline C5ZZ
« Reply #13 on: May 18, 2013, 09:44:53 PM »
Do tell.
Tony K.
Tony, its a plastic tip.
MCA # 00945
Offline C5ZZ
« Reply #14 on: May 19, 2013, 09:41:10 AM »
Yours may or may not be missing the black metal bracket.
Here are some pictures of a NOS unit I dug out tonight:
Mine doesn't have the black metal bracket and there is not a need for it,
the hole in the dash has a flat side which lines up with the flat on the
switch so it fits in perfectly. Also the wiring on mine is a little different
from yours, I don't have the blue extension wire and it hasn't been cut
off, I have two of these flashers and they are both the same.
Maybe mine are from a factory install where yours is a over the counter accessory.
MCA # 00945
