Author Topic: 6 cylinder A/C hose bracket 66 mustang  (Read 2660 times)
Offline tnguy624
« on: July 04, 2013, 09:59:27 PM »
I am installing factory original a/c in my 66 convertible 6 cylinder built in dearborn with a build date of jan 66. I am looking for the brackets for the a/c hoses that bolt to the shock tower braces. They are part numbers C6ZA-19812-B AND C4ZA-19812-B. I know they are not reproduced and I have never found any used ones. The Ford master parts manual pictures of them are not clear enough, and I was wondering if any one had some pictures of what the originals looked like so perhaps I could manufacture them.
Thanks so much for any help or pictures anyone might have.
Terry
« Last Edit: December 21, 2020, 05:43:21 AM by J_Speegle »
1966 Convertible
Born Jan. 17, 1966 Dearborn
Rebirth began Feb. 2012
Reborn July 2013
1966 Sprint
Born  May 27, 1966  Dearborn
D-4 Interior: Parchment/Emberglo
V    Exterior: Emberglo
Rebirth began March 2009
Reborn May 2011
Moved to Australia Dec. 2011
MCA # 78931
Re: A/C hose bracket 66 mustang
« Reply #1 on: July 08, 2013, 12:06:56 AM »
Are these the metal or rubber tire scrap ones?
Just back from a show and will dig out some pictures
Offline drummingrocks
« Reply #2 on: July 08, 2013, 12:53:52 PM »
If they're the rubber type that bolt to the brace between the shock tower and cowl, then I can at least help with pictures.  Though my car doesn't have A/C, it does have the straps supporting the heater hoses to the brace.  Not sure if that's the same application as what would've retained the A/C hoses or not.
Offline C5ZZ
« Reply #3 on: July 08, 2013, 10:26:11 PM »
Here is a picture of a very dirty engine compartment (not mine) that shows the brackets installed.
I should also have the brackets themselves that I can take pictures of.
MCA # 00945
65 Fastback, 6 cyl, AT, AC, PS, PB
Rangoon Red/Red Interior
« Reply #4 on: July 08, 2013, 10:46:37 PM »
Found them - here are a few of the bracket - sorry for the resolution
Offline C5ZZ
« Reply #5 on: July 08, 2013, 10:49:40 PM »
Here are some pictures of the brackets themselves,
a little bent up and rusty but gives you the idea.
MCA # 00945
Offline tnguy624
« Reply #6 on: July 10, 2013, 12:09:16 AM »
Thanks to you all so much for the replies. Thanks as well for moving the post, as I wasn't sure where it should go. I do have the original "used tire" strap for my heater hose.  With the pics I should be able to make something or at least know what to look for!
Terry
1966 Convertible
Reborn July 2013
1966 Sprint
Reborn May 2011
MCA # 78931
« Reply #7 on: July 10, 2013, 07:16:07 PM »
.............. Thanks as well for moving the post, as I wasn't sure where it should go. ..............
Your welcome
Just so you and other readers understand items are placed in the RESTORING SECTION when the subject spans many years of interest so that the information can be shared across those different periods .
If the subject is specific to one year then it gets placed in the Specific Year Section by Generation so that others can find it in the future
