Author Topic: Rear pumpkin markings - after evapo-rust  (Read 5369 times)
« on: July 25, 2013, 11:28:02 AM »
Soaked a disassembled rear pumpkin housing in evapo-rust.  Markings can be seen perfectly and great reference item.  The rear was out of a February (04B) '65 San Jose C code coupe.  Date casting of 4M28.
Offline livetoride60
Re: Rear pumpkin markings - after evapo-rust
« Reply #1 on: July 25, 2013, 12:50:02 PM »
Great reference!  Thanks Charles.
'65 K code Fastback, 4sp, San Jose, 10/9/64
'66 C code Coupe, C4, Dearborn, 5/24/66
'67 Fairlane Convertible, 3sp, 200 I6
Offline outlawincorporated
  • Kangaroo Herder
« Reply #2 on: July 25, 2013, 03:46:34 PM »
There will definitely be several containers of evapo-rust in the next container I ship home as I haven't been able to locate a supplier here in Australia to date.
Fantastic results, have you done the entire drive-shaft yet??
and could you confirm is the writing in yellow or white, sometime images make paint markings look a different clour
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
« Reply #3 on: July 25, 2013, 04:27:38 PM »
I have a PVC tube for driveshafts.  Think the writing is white.  Combination of markal and paint marker.  Interesting to see how neat the 'OK' was written.
Offline Toploader
« Reply #4 on: July 25, 2013, 05:32:04 PM »
Looks good.
Was there any pretreatment? Not knowing this particular case, what I specifically have in mind is years' worth of crud and grime. As far as I'm concerned the Evapo-Rust will only take care of the rust. I guess any pretreatment would have to be done with delicacy.
76A-Y-D2-13H-72-6-6
1965 Californian Built Silver Blue Convertible
« Reply #5 on: July 25, 2013, 06:41:01 PM »
Yes, cleaned the grease/dirt off of it in my parts washer before soaking.
Offline Aussiemach
  • Silver Level Subscriber
« Reply #6 on: July 25, 2013, 07:37:32 PM »
Phill, I bought 200 Litres from David 3 years ago or so. Here is the web site;
http://www.evapo-rust.com.au/
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
« Reply #7 on: July 25, 2013, 11:47:19 PM »
I have not tried it yet but have heard that vinegar can be used with similar results. If it works it would be cheap and readily available, just smells bad.
Marty
Offline rodster
« Reply #8 on: July 25, 2013, 11:58:24 PM »
Very interesting markings. Makes me want to run out and throw a bunch of my 65 stuff in a big vat of Evapo-rust.  ;D
I tried vinegar on some bolts and rotors and it seemed to work ok but maybe not as fast? For the price of vinegar it's worth some experimenting.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #9 on: July 26, 2013, 12:41:14 AM »
Vinegar is mainly acetic acid.  Evapo-rust is not acid, it will not harm the metal, it just targets rust and removes it.
Offline petersixtfive
« Reply #10 on: July 26, 2013, 01:26:22 AM »
Phil
All Time Machinery Sales
12/355 South Gippsland Hwy
Dandenong South
3175
PH: 03-87875415
I buy 5lt units
i wouldnt like to buy larger units as it seems to have a usable life
I have done a driveshaft in 2.5 to 3 litres in a 100mm UPVC sewer pipe with capped ends
I didnt get a lot more usable life from the product after the driveshaft
Cheers
« Reply #11 on: July 26, 2013, 10:41:01 AM »
It helps to keep the parts in only as long as necessary to remove the rust.  Leaving things in there for multiple days will quickly degenerate the effectiveness of the solution.  It can be a huge time saver when one considers the time that would be required to blast the parts in a cabinet.  I can easily justify $95 for a 5 gallon bucket of evapo-rust.
  • Kangaroo Herder
« Reply #12 on: July 26, 2013, 11:10:30 AM »
Thanks for the tips Australian members, will definitely follow through on those contacts.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Offline Toploader
« Reply #13 on: July 26, 2013, 05:00:18 PM »
I use to run the solution through a paper filter right after use - to keep it as clean as possible. This seems to prolong the life span of the solution considerably.  You can triple the price compared to the US when buying Evapo-Rust in this part of the world (Denmark, Europe).  :-\
Just discovered the new thread about Evapo-Rust. Sorry.
« Last Edit: July 26, 2013, 05:09:04 PM by Toploader »
76A-Y-D2-13H-72-6-6
Offline rockhouse66
« Reply #14 on: July 26, 2013, 06:57:30 PM »
FYI - $80 at Northern Tool and you can order it online and pick it up at the store no extra charge.  I picked up a 5 Gal. bucket today.
PS - I know this doesn't help our Australian friends - sorry  :(
'66 GT FB
