Author Topic: Front Brake Lines - 67 Drum  (Read 10222 times)
Offline sparky65
« on: February 16, 2010, 09:46:54 PM »
I decided to use new brake lines instead of refinishing my old ones.  I found out that the front lines are very diffrent.  My original ones were routed under the bracket on the frame rail before looping back to the bracket.  The new ones are bent to route over the top of the bracket.  The car has manual drum brakes.  Is this a poor repro or were there diffrent routing?  On a related note the screws that came with the brake line clamps seem to be too small for the holes so I will have to reuse the old ones.  Makes me think that the routing may have varied at some point in 67.
« Last Edit: February 16, 2010, 11:31:32 PM by J_Speegle »
Steve
1967 Pebble Beige  I6 Coupe built in Metuchen on Oct 26, 1966.
2009 Black GT Coupe
Re: Front Brake Lines
« Reply #1 on: February 16, 2010, 10:04:14 PM »
Here are some pictures of mine.  The one with the bracket is on the pass side, other is driver's side. There are 2 pics of driver's side, one showing where the bracket was removed.  Dec 1966 San Jose.  Driver's side rubber grommet had fallen out. Hoses had been replaced in ~2000 with ones from NPD, not NOS.
Re: Front Brake Lines - 67 Drum
« Reply #2 on: February 16, 2010, 11:39:46 PM »
I decided to use new brake lines instead of refinishing my old ones.  I found out that the front lines are very diffrent.  My original ones were routed under the bracket on the frame rail before looping back to the bracket.  The new ones are bent to route over the top of the bracket. ................  Makes me think that the routing may have varied at some point in 67.
Not so sure - may be a difference between the plant suppliers again
Sorry not allot of  pictures of this area of the car and often the suspension blocks what would have shown everything your looking for. Below are what I did find of drum brake cars from all three factories - Draw your own conclusion
7T01T181321
7T01T131041
7R02A174875
7R02C216375
7F01C128538
Offline Sunlitgold68
« Reply #3 on: February 17, 2010, 01:31:51 PM »
This is what worries me about getting some reproduction lines that I know will not be correct and bent in a generic fashion.  :o
8T01C204XXX
Built May 14th, 1968
« Reply #4 on: February 17, 2010, 02:07:27 PM »
What you will find is that any reproduction brake/fuel line that is not exact will be close enough for you to work with.
Offline gtamustang
  • CPM
« Reply #5 on: February 17, 2010, 03:13:15 PM »
You are personally experiencing the difference between early and late model 67 Mustangs! There were quite a few running changes in 67 and the brake lines were one of them. I wound up buying 4 different line sets to find the closest match for a driver resto that I recently completed.
Regards,
Pete Morgan
« Reply #6 on: February 17, 2010, 04:03:58 PM »
Is the bracket in the last photo also dipped in black paint for 1968? Was thinking zinc?
8T01C204XXX
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #7 on: February 17, 2010, 05:51:38 PM »
Hi sparky65,
If the repop is not stainless, can't the last part with the horseshoe be TWISTED 180deg?  It looks like to me this would get you where you need to go.???
Bryan
66 Metuch Conv
Nightmist, Std Blu Int
Offline sparky65
« Reply #8 on: February 17, 2010, 07:24:38 PM »
Regards,
Pete Morgan
Pete,
I got these from NPD part# 2265-9 back in 2007  its still listed in the catalog for an early 67.  Were yours bent the same way and did you actually find ones that were bent the way my originals were and do you remember from where?
7T01T131041
This one has the closest VIN mine is about 4000 higher.  Anyone know if the change over for all the other brake line changes took place around the same time at each of the plants?  I would assume each plant would use up the old stock first but how much would each plant stock I can't imagine it would be more then a months worth.  I ask becouse the 7F01C128538 one actually has a lower consecutive number but is from a diffrent plant.
Hi sparky65,
Bryan
I don't think so. All the repop lines needed adjustment but I think twisting it 180 degrees would be too much.  Also the 90 needs to be lower as well so that it runs along the bottom of the rail.
Steve
2009 Black GT Coupe
Offline bryancobb
  • 2009 Ridn' Around
« Reply #9 on: February 17, 2010, 08:04:29 PM »
Not to be hard-headed, but I don't know about that.  The steel in the brake lines is soft as butter.  Try it.  What have you got to lose?  A $20.00 brake line and shipping?  I bet it will work.
66 Metuch Conv
« Reply #10 on: February 17, 2010, 09:21:41 PM »
You are personally experiencing the difference between early and late model 67 Mustangs! There were quite a few running changes in 67 and the brake lines were one of them. ...............
Pete - when was the change?
Pictures suggest some where before Dec at Dearborn
Between Nov 66 and Jan 67 at NJ
Before Jan 67 at San Jose
