Author Topic: Override Traction Bar boot from Heavy Trucks parts bin  (Read 6396 times)
Offline Ogresko
  • 1965 C Code Honey Gold Fastback (modified)
« on: February 27, 2014, 11:05:16 AM »
I am wondering if anyone knew a part number or truck reference for the rubber boot that was later added to the override traction bar to keep moisture, fumes and dust from entering the car. I do have the fiberglass cover and have seen the rubber with the slit also just looking for the one Shelby decided to use. It is also referenced in the Definitive Guide but alas no truck model or part number. Just mentions Ford's Heavy Truck parts bin. I am not building a clone as I am returning my 65 fastback to it's Honey Gold but I do want to have it have similar parts and period correct mods as the GT-350, hi-po heads, T10, Shelby manifold, 715CFM carb, tri y's, arden drop, no corrale, fiberglass hood no stripes, etc.
thanks
Re: Override Traction Bar boot from Heavy Trucks parts bin
« Reply #1 on: March 01, 2014, 11:35:31 PM »
Don't have the part number of the trunk shifter boot that some used to do that job -
Jim did just post over on the SAAC site today that he had a pair for sale
http://saacforum.com/index.php?topic=26972.0
Offline Texas Swede
« Reply #2 on: March 04, 2014, 10:11:29 AM »
This part number was listed in the old SAAC Magazine The Marque many years ago.
I believe it was a C7 number. I bought a pair I used in my 65 GT350 for many
years until I decided to go back to original, i.e. Good Year Inner Tube that a friend
was kind enough to give me. However, these worked perfectly but don't look exactly
the same as the originals on the early 66's.
I believe you can find this complete number on the web. Know I did some years ago.
Texas Swede
« Reply #3 on: March 04, 2014, 09:01:10 PM »
Challenge, with the part number, will be finding a pair. :)   Good luck with your search
Offline Ogresko
« Reply #4 on: March 13, 2014, 12:23:06 AM »
I am now going with the fibreglass covers but the fit is terrible. Will make do with what I have. Does any one know the rough dimensions of the hole in the floor for the bar to  go through.? I looked through my definitive shelby guide and also on line but there is no reference to the hole size. Also appears that the sheet metal for the mounting of the interior side panel needs to be removed. Not sure if this is accurate.
Offline rockhouse66
« Reply #5 on: March 13, 2014, 09:56:08 AM »
I snagged this photo somewhere so am sharing it in answer to your question.
'66 GT FB
Offline Ogresko
« Reply #6 on: March 14, 2014, 02:49:20 PM »
That is an excellent angle. It shows the hole with clear reference landmarks. I will post some pics once they are in.
Thanks for the pic
Offline Ogresko
« Reply #7 on: September 16, 2015, 06:09:32 PM »
Here is Ford truck shifter boot installed in a 1965 fastback
Offline WT8095
  • Dave Z.
« Reply #8 on: September 16, 2015, 08:35:01 PM »
From http://saacforum.com/index.php?action=printpage;topic=7582.0:
Quote
Steve,
  Yes, the P/N is: C7TZ-2A713-C,  Brake Lever Boot.  I have them on my carryover car. They work great, sealing off this area, and
  they make it look finished, like a factory installation.
  They are obsolete, very hard to find, so if you have a pair, you are lucky.
   Doug
Dave Z.
