Author Topic: 65-66 Windshield Washer Pump Feed  (Read 2338 times)
Offline Twilight65
  • Gold Level Subscriber
« on: March 06, 2010, 11:03:22 PM »
I purchased what I thought was a correct windshield washer pump feed wire for my single speed washer pump. When I received it, the wire was vinyl and my original (pictured below) though damaged has a cloth protection around it. A little different grain then the asphalt wire loom but kind of the same. It has this covering all the way through the firewall to the wiper switch. Has anyone else seen this? if so does anyone know who carries a correct replacement?
Dave
« Last Edit: March 16, 2013, 06:12:39 PM by J_Speegle »
Re: Windshield Washer Pump Feed
« Reply #1 on: March 07, 2010, 12:37:17 AM »
Yes, I have seen the covering.  It isn't something I have paid much attention to, though.  Seems like I remember seeing it on '66 cars, mostly.  Hopefully others will weigh in with their observations.
Offline Bill Cabaniss
« Reply #2 on: March 07, 2010, 09:15:34 AM »
 My 66 has the exact same covering you describe all the way through the firewall. Your only hope might be through a salvage yard since this is such an odd piece of wiring. Bill.
Highland green 68 GT fastback/concours driven since 2000. 8f02j - 1-23-68
raven black 66 coupe/concours driven since 1991.6f07c- 5-14-66
rangoon red 65 Mustang JR. go-cart serial#02. not driven much.
Still drive them to the nationals/they do clean up!
Gold card judge for 67-68 concours class.
« Reply #3 on: March 07, 2010, 09:22:34 AM »
It's a tight woven covering if I remember right.  Not simply the asphalt covering like the gas sending unit feed.
« Reply #4 on: March 08, 2010, 09:04:45 AM »
 My covering is tight. It is just big enough for the one wire to fit inside. It is dark in color and stiff going up and across the shock tower, but where it goes in the rubber grommet at the firewall it is softer and mine has frayed a little. There are two strands of the woven material hanging loose that look just like the interior braided wire covering you would see  under the dash or on the tail light wiring harness. Hope this helps. Bill.
Offline Twilight65
« Reply #5 on: March 08, 2010, 08:31:27 PM »
Thanks Bill,
Mine is the same it's only an 1/8" in diameter. It was cut and looks to be 1 strand of a solid copper conductor with vinyl then the cloth. When you bend it, it stays put.
Dave
« Last Edit: March 08, 2010, 09:05:42 PM by Twilight65 »
Offline rodster
« Reply #6 on: March 16, 2013, 12:56:38 AM »
Not too late to weigh in is it?  ;D  Hmmm  3 years later but hey this site contains timeless info!  ;)
Was just looking at this area and here's what is on my 65 Dearborn car, no covering on the wire and it runs to the firewall outside of the harness. I can faintly see part numbers on the wire so I'll have to clean it up.
Does this look/sound 'correct'?
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
