Author Topic: How to remove rust stains?  (Read 2405 times)
Offline Hipo giddyup
« on: July 06, 2014, 10:00:02 PM »
Not sure where else to post this. I have noticed a rust stain on my paint from a bare metal or phosphate covered part. This is on the passenger side of my 1967 coupe door jamb and is the metal attachment for the roof rail weatherstripping. Curious if there is a chemical that will remove this stain. Kinda like a "magic erase" for the car. This is also base coat clear coat. Thanks
Re: How to remove rust stains?
« Reply #1 on: July 06, 2014, 11:36:03 PM »
I would remove the screw. move the end of the weather strip up and clean that area with some light polish. Then treat the rust, oil the end and the screw and put everything back together.
Has worked fine for me - on single stage paints
« Reply #2 on: July 07, 2014, 12:25:57 PM »
 Any suggestions on products??? Would evaporust "destroy" the rust on contact?? I have not used it yet but have heard great things about it.. If not, any other brands?? Thanks so much.
« Reply #3 on: July 07, 2014, 02:04:16 PM »
Evapo-rust requires parts to be soaked and it will lift paint on parts left in the bath, I would definitely not even consider it.  All this needs is a little bit of hand polish to rub it out as Jeff mentioned.
« Reply #4 on: July 07, 2014, 02:20:11 PM »
 Thanks, I'll give it a try and post a pic.. :)
Offline sportyworty
« Reply #5 on: July 12, 2014, 12:18:29 AM »
If it is still there after a light rub try a clay bar and White Vinegar, next Acetone lastly CLR
 Home Depot carried it.
« Last Edit: July 12, 2014, 12:20:41 AM by sportyworty »
Offline 1forfords
« Reply #6 on: October 15, 2014, 10:17:31 PM »
There is a product called "Whink", it works like magic on rust stains. I have used it on numerous surfaces with no problems, but I would test an area.
