Author Topic: Radiator Line Connections  (Read 4579 times)
Offline Sunlitgold68
« on: August 01, 2009, 07:15:38 PM »
Can you transfer the auto transmission line connectors from one radiator to another?
What finish should they be?
What is the purpose of the rod that attaches at the midway point from side rail to side rail, is this a safety measure so the core doesn't get too much stress from the wind?
8T01C204XXX
Built May 14th, 1968
Re: Radiator Line Connections
« Reply #1 on: August 01, 2009, 08:28:17 PM »
As long as the application is the same, year for year and the same application. In other words you don't want to try making a 69 FMX set of lines fit a 65 C4
The lines (if I remember correctly - but surely someone will remark if I screwed up) were tin dipped originally. Would guess that the reproductions are zinc coated
The rods attached in the middle of some radiators are often missing (left off by rebuilders) I think are just designed to hold the side straps in place or deforming outward. I'm sure they could bend outward from a number of things.
« Reply #2 on: August 06, 2009, 10:07:04 AM »
Would it be feasible to have original transmission lines replated in "tin"
What about the fuel line from fuel pump to carburator?
8T01C204XXX
« Reply #3 on: August 09, 2009, 02:16:58 PM »
IMHO no it would not be feasible- you might get a shop to dip it (if they have a large tank) in zinc and then tone that down
Same goes from the pump to carburator the challenge would be getting the fitting off of the end
