Author Topic: Yellow top coil restoration tip  (Read 21043 times)
Offline livetoride60
Re: Yellow top coil restoration tip
« Reply #15 on: October 10, 2014, 09:13:44 PM »
Awesome.  Was looking for a good yellow, so thanks.
'65 K code Fastback, 4sp, San Jose, 10/9/64
'66 C code Coupe, C4, Dearborn, 5/24/66
'67 Fairlane Convertible, 3sp, 200 I6
Offline Texas Swede
« Reply #16 on: October 11, 2014, 12:38:10 AM »
Brian, I don't believe the number/letter between the posts are date codes but molding numbers. Date codes are shown in the stamps.
Texas Swede
« Reply #17 on: October 11, 2014, 12:51:15 AM »
Texas Swede
+1.
Offline Brian Conway
« Reply #18 on: October 11, 2014, 01:01:30 AM »
Thank you guys.  To bad that 5D one is the same date code as my air cleaner.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #19 on: October 11, 2014, 01:06:50 AM »
Why to bad? You can still use it along with your 5D dated air cleaner. Just make sure the ink stamp on the coil is dated correctly.
« Reply #20 on: October 11, 2014, 12:16:36 PM »
Care to elaborate on ' ink stamp ' ?  A SEARCH of 65 Coil did not include any further info.  I know a couple of decals are available but short of having a specialty shop doing it I am unaware of a at home remedy.  Thanks,  Brian
« Last Edit: October 11, 2014, 12:20:37 PM by Brian Conway »
San Diego, Ca.
Offline lancelot66
« Reply #21 on: October 11, 2014, 12:44:48 PM »
Brian,
It would be along the lines as this one currently on eBay:
http://www.ebay.com/itm/Ford-Mustang-coil-marking-stamp-boss-302-429-428CJ-SCJ-FAC-12029-A-AUTOLITE-/141429229198?pt=Vintage_Car_Truck_Parts_Accessories&hash=item20edd6c68e&vxp=mtr
Date on the right side of the stamp would naturally need to be correct for your car. I'm a decal user currently, but it would be a nice detail to upgrade for sure.
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
« Reply #22 on: October 11, 2014, 05:38:12 PM »
Thank you for the post.  I usually try to watch the costs vs parts and this one looks like it could get pricey.  Brian
San Diego, Ca.
Online jwc66k
« Reply #23 on: October 11, 2014, 07:01:02 PM »
I made the artwork for a stamp and took it to a local stamp maker where he gave me a quote of under $10. I left the date code part blank with the intent of making separate date code stamps for my three cars and four other local Mustang owners. The date code stamp were about $7 each. I didn't order one as some priorities came up.
The method I've seen that works was to mount the stamp face up on a frame and roll the coil to get the marking. The date code would be done "free hand".
Offline Texas Swede
« Reply #24 on: October 11, 2014, 11:59:25 PM »
Hi Brian,
Here are pictures of the coil I use on my 65 Shelby, 5S275.
Texas Swede
« Reply #25 on: October 12, 2014, 10:41:19 AM »
Thanks for the pictures.  Now I understand the bracket w/hole and coil w/keyed bumps.   How do I get a coil that looks like that ?   Brian
« Last Edit: October 12, 2014, 10:50:22 AM by Brian Conway »
San Diego, Ca.
Offline Texas Swede
« Reply #26 on: October 12, 2014, 10:56:10 AM »
I bought the coil from JD Larson. The bracket with the hole I already had.
At that time, some years ago, I had a discussion about the coil. Should it have the button
or not? Should the bracket have the hole or not. Conclusion was I should have both.
My car was built in San Jose between May 7-10, 1965. Original engine assembly date May 3
and car received at Shelby American on May 13.
Texas Swede
« Reply #27 on: October 12, 2014, 11:42:41 AM »
Thank you for sharing all that info.  This AM, from JD Larson, that same 5DCB set up with correct bracket will cost you $450.  Brian
San Diego, Ca.
Offline lancelot66
« Reply #28 on: October 12, 2014, 12:41:45 PM »
That is one fine looking coil you put together Texas Swede. Gorgeous! But Brian, I'm with you on this (and many other areas) as I'm trying to keep my costs down also. The folks out at: http://www.427galaxieregistry.com/Fordyellowtopcoil.html are looking better and better with those prices that keep going up. Market indicator I guess. I've dealt with JD Larson too and I like him. He's good. Our present coil is a good baseline for this type of restoration so will consider all this advice too. We don't have the resources where we live to get that stamp made either, especially at those great prices.
I might give that a crack if we did. I sure like the idea and how that came out too.
VR/
-Lance
SJ Build Date: 1/6
Offline Texas Swede
« Reply #29 on: October 12, 2014, 03:21:43 PM »
$450, that is a lot. If I remember correctly I bought it for $150.
The funny thing though is that when mounted correctly at my 65, nothing
of the stamp can be seen as it's completely hidden behind the bracket.
I am attaching a picture taken in Paris, France of 5S114's engine compartment.
Same thing, no stamp can be seen.
Texas Swede
