Author Topic: 1969/70 shelby license plate hardware  (Read 2452 times)
Offline 1970shelbyguy
« on: September 25, 2014, 08:54:58 PM »
 picked up my washers and nuts but what kind of screw was used to attach the bracket to tail panel- thanks
1970 gt500  grabber blue  june/69     1970  boss 302  metuchen  dec/69
Re: 1969/70 shelby license plate hardware
« Reply #1 on: September 25, 2014, 09:45:02 PM »
The rear license plate bracket had studs that attach it to the taillight panels not screws. They pass through the panel and are held in place by washers and nuts on the trunk side. The studs are part of the lower hinge brackets - shown on page two of the Faux Galvanizing article located in the Library on this site
« Last Edit: September 25, 2014, 10:52:16 PM by J_Speegle »
« Reply #2 on: September 25, 2014, 10:05:35 PM »
well something new here- i'll have to check it out.  thanks jeff
« Reply #3 on: September 25, 2014, 10:32:24 PM »
hey jeff it looks like my bracket is a different style-  the two hinged tabs have a hole in them to take a bolt- there's a plate bracket on ebay currently  that might be the correct one- says torino shelby etc.  shows what looks like studs@ hinged tabs- can you verify. rgds  david  70 gt500
« Reply #4 on: September 25, 2014, 10:42:51 PM »
was the orig  rear plate bracket from a cougar?  possibly a 68 or 69 style?
« Reply #5 on: September 27, 2014, 05:58:49 PM »
Believe it might match a 69 Cougar - never compared side to side (didn't match a 71 version)
Sounds like all your missing is the two mounting studs
« Reply #6 on: September 27, 2014, 06:48:30 PM »
yup -where the studs should be there's a pair of round holes.  they look like fact punched so bracket was replaced at sometime in it's life.  has the offset  pull handle at the top.  seen some reference to a 68 or 69 fairlane as being the proper bracket.
« Reply #7 on: October 01, 2014, 01:06:59 PM »
c8oz ford #
