Author Topic: 67 390 Carb  (Read 4483 times)
Offline rodster
67 390 Carb
« on: October 01, 2014, 09:53:28 PM »
I'm about to send a C7OF 9510 B out for a rebuild and was wondering if there are any parts I should request be reused in order to keep it as correct as possible?  Would hate to get it back and the first person that looks at it says what happened to the (fill in blank)?    Originals are impossible to find!  :o
I will remove the aluminum tag for safe keeping.  Speaking of tags, were they always attached at the same spot over the years?
The choke cover doesn't look original since I don't see a Ford logo of any type?  Two different styles of needle/seat too.
My knowledge of carbs is weak so I appreciate the help.  :)
Thanks!
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Re: 67 390 Carb
« Reply #1 on: October 01, 2014, 11:11:24 PM »
Would expect them to reuse all of your parts or maybe (depending on builder) swap some out for already done (plated) individual parts. YOU can always ask to use only your parts. Some will automatically replace the fuel bypass which should not be a big issue.
Since you took pictures pay attention to the finishes of the arms and linkage - you will likely need to redo or recolor some of those. It always seems they plate the accelerator lever dichromate :(
Basically just about everything that can get plated (other than the carb body parts) get dichromated. Would expect that you will get the original carb tag back
Often I remove some or all (or ask them not to stamp) the inspectors, numbers and such  - just do those myself when I receive it back
Offline rodster
Re: 67 390 Carb
« Reply #2 on: October 02, 2014, 01:46:24 AM »
Thanks for the input Jeff.  I guess I can always request any old parts returned to me as well.  I'm not asking for a full blown concours restoration, just a decent rebuilt so I suspect I will need to redo some things.
I will be keeping the tag and the shop agrees that's a good idea.
1984 SVO - 2A
Re: 67 390 Carb
« Reply #3 on: October 02, 2014, 07:57:21 AM »
I would use Kurt formerly with Pony Carbs for this task.
If you need contact info, I can look it up. It was discussed recently in another 67 S-code thread (about 2 months ago) and I think the contact info was mentioned there.
PM me to Q me on the contact info
Offline sportyworty
Re: 67 390 Carb
« Reply #4 on: October 02, 2014, 12:04:26 PM »
Rodster your choke cover appears correct. Nice complete correct carb in general
Offline rodster
Re: 67 390 Carb
« Reply #5 on: October 02, 2014, 01:34:38 PM »
Interesting I would have guessed (wrong) the choke cover was not original.  ::)
Thanks on the confirmation on the general completeness of the carb.
1984 SVO - 2A
Offline Hipo giddyup
Re: 67 390 Carb
« Reply #6 on: October 02, 2014, 02:06:30 PM »
 I think your carb missing the vacuum fitting on the front metering block?? My core carbs all have this. Possibly needed/not needed between standard and automatics but most every one that I have seen has this. Sorry for the crappy copied pic. :-[
Offline Paperback Writer
Re: 67 390 Carb
« Reply #7 on: October 02, 2014, 02:41:18 PM »
+1 on the missing vacuum fitting...
Probably not 100% concours as far as finishes go, but here are some photos of the C7OF 9510 B carb installed on my car:
http://www.concoursmustang.com/forum/index.php?topic=8418.msg48814#msg48814
1967 390 GTA Convertible
7R03S110###
Offline rodster
Re: 67 390 Carb
« Reply #8 on: October 03, 2014, 09:54:43 AM »
Thanks for the info and pictures. I wasn't sure if every carb got the vacuum fitting.
Another thing I'm confused about is dashpots. Papepback Writer, your reference photos show no dashpot but it's an automatic trans car?  I know the purpose of the dashpot but is it true only cars with AT got them?
I would like to find a vacuum fitting before I send the carb out.  I see there is a reproduction version available and being a relatively simple part should be close to 'correct'.
1984 SVO - 2A
Re: 67 390 Carb
« Reply #9 on: October 03, 2014, 12:13:01 PM »
Another thing I'm confused about is dashpots...  ...I know the purpose of the dashpot but is it true only cars with AT got them?
I beieve the need for the dashpot was With BOTH auto AND A/C, but my research was as such. I didn't research the two options by themselves (read as AT only, no A/C or Man Trans car WITH A/C)
Offline mtinkham
  • That'll be easy
Re: 67 390 Carb
« Reply #10 on: October 03, 2014, 01:40:31 PM »
I have a 67 322A 390 Engine that has a dash pot.....manual transmission and no AC.  I will confirm date code as it is not original to my car.
Offline tim_morrison82
    • Click Here for My Project
Re: 67 390 Carb
« Reply #11 on: October 04, 2014, 12:36:16 PM »
I used formally pony carbs and although the carb turned out nice and clean, I was happy at the look of what was there, but matching the photos of what was sent and what was recieved after restoration, even after requesting all parts are sent back I was missing parts... I ended up buying another $300 of nos parts to finish the job to the standard I was told I would recieve when I sent the work that way...
Offline rodster
Re: 67 390 Carb
« Reply #12 on: October 04, 2014, 12:45:09 PM »
Yea, that's one of my fears. I'm starting with a basic good core and don't want to go backwards as far as 'correctness' is concerned.
I've thought about just cleaning up my core and doing a rebuild myself but hard to duplicate the experience some of the rebuilders have.
Perhaps if I'm very specific about what I want done, all will turn out well.
1984 SVO - 2A
Offline rodster
Re: 67 390 Carb
« Reply #13 on: January 03, 2015, 08:17:05 PM »
Got my carb back and I'm very happy with it. Sure looks better.  ;)  and can't beat the price ($160) and one week turn around time.  Body is plated, not painted and the carb was bench tested.
I haven't re-installed the carb tag yet.
« Last Edit: January 03, 2015, 08:20:13 PM by rodster »
1984 SVO - 2A
Offline mikelj5S230
  • 1964 1/2 K code coupe, 5S230, and 2022 GT500 HE
Re: 67 390 Carb
« Reply #14 on: January 04, 2015, 10:11:54 AM »
Looks very nice, be sure to adjust the fast idle screw before you install it, getting it close is much easier when it is off the car, IMO.
I don't always downshift, but when I do it is near a Prius so they can hear me hurting the environment.
