Author Topic: 1970 NJ Pinch Weld blackout  (Read 1939 times)
Offline jatkinson
« on: April 05, 2016, 06:11:57 PM »
Looking for info for the pinch weld blackout on a NJ 1970 Mach 1. I looked at the post on the 1969 and it looks like all plants blacked the weld out. Is it the same for 70?
« Last Edit: April 06, 2016, 04:39:21 PM by J_Speegle »
1970 Metuchen Mach1 Medium Red 351C 4v Auto PB Shaker Black Interior
Re: 1970 NJ Pinch Weld blackout
« Reply #1 on: April 06, 2016, 06:16:23 PM »
Believe the black extended further up the side to cover the gap between the rocker(pinch weld) and the side cladding for the same purpose as the black out between the panels on the quarter panel, door, front fender. Any (especially with all the bold bright colors)  showing through the gaps really stands out when a 70 Mach I is viewed from the side on those cars - a real distraction ;)
Will look got some pictures to illustrate.
« Reply #2 on: April 07, 2016, 09:24:28 AM »
70 mach 1s also had blackout across the trunk key hole area & between rear honey comb panel ends & chrome taillite bezels
Offline jatkinson
« Reply #3 on: April 07, 2016, 02:40:39 PM »
Thanks for the replies. Pictures would be great Jeff. The blackout area on the rear is correct, on my car, but it is not on the pinch weld.
« Reply #4 on: April 07, 2016, 10:36:53 PM »
Well here is what I can offer - always wish it was more and the examples were more pristine but unfortunately when it comes to especially NJ cars its a bit tougher to find them.  After looking at the pictures I see my comment above was not exactly correct. The painters did not reach where the molding would overlap as much as I thought it would - just a little short. Guess the angle of the rocker and the cladding kept that area out of view anyway.
Small sampling so they might have gone higher on some examples but from what I've got its only a maybe - not a fact at this point
Hope these help you in with your project
Not a Mach I detail but threw it in to remind those viewing that this was done before the front fenders were installed ;)
A little weak possibly due to the elements, cleaning  ::)  or a repaint
Offline jatkinson
« Reply #5 on: April 08, 2016, 11:08:02 AM »
Thank you very much. That is exactly what I needed....
