Author Topic: 70 Dearborn rocker meets rear quarter  (Read 1019 times)
Offline 70boss2wv
« on: July 08, 2017, 07:19:02 PM »
Does anyone have any pictures of what the joint between the rocker panel, and the rear quarter panel should look like?  I'm especially interested in the lip of the wheel well in this area.  Does the joint with a gap continue around the lip of the wheel  well, or is the joint filled in as it goes around the corner, so to speak. My car was built April 30, 1970 Dearborn.
Offline ExportMach
Re: 70 Dearborn rocker meets rear quarter
« Reply #1 on: July 08, 2017, 07:49:04 PM »
here is a pic of my mach at the resto shop. My Dearborn Mach was bucked in mid-March 1970.
Mark C
« Reply #2 on: July 09, 2017, 04:09:30 PM »
If its like other years and plants you should be able to see the seam between the two panels as it rounds the corner and goes into the wheel well to the edge of both panels. You should also see a blob of the brazing that held the panels together at one point before the spot welds were applied Will look to see if I have a close up to post
Thanks for including when and where your car was built ;)
« Last Edit: July 09, 2017, 04:20:32 PM by J_Speegle »
« Reply #3 on: July 09, 2017, 04:42:45 PM »
Here are some examples - sorry for the resolution some were taken from much larger pictures that did not focus on this one detail
Hope these help
0F1166xx
0F1176xx
0F1468xx
0F1516xx
0F April
