Author Topic: 1967 390 GT Dearborn engine inspection markings  (Read 3391 times)
Offline Rossco
« on: September 09, 2017, 04:29:51 AM »
Morning just been reading some information on the 69 Mach 1 further down in the section and would like to know the same really for a Jan 9th Dearborn 390 engine with GT package
I have seen the X on the headers or the S or even the OK stamp on the valve covers, but as Jeff said better with No markings than wrong Markings
Wondered if anyone has any info at all?
Ross
Re: 1967 390 GT Dearborn engine inspection markings
« Reply #1 on: September 09, 2017, 04:48:51 PM »
Since these markings were placed on the engine at the engine plant this detail would not be car plant specific but instead engine plant specific so moving this over in the 67-8 section.
Will post a couple of comments once I look up examples and notes but would not suggest that markings from a 69 would be the same for an engine two years earlier. We will see ;)
« Last Edit: September 09, 2017, 04:58:53 PM by J_Speegle »
Offline Rossco
« Reply #2 on: September 09, 2017, 05:01:11 PM »
Ok Jeff
« Reply #3 on: September 09, 2017, 05:02:12 PM »
Took a look and could only confirm (number of examples that all had the marking) what appears to be a number on the forward face of the drivers side head surface.
Appears that they were applied (likely the difference was a different worker) with a circle around the number and without.
Number was single or double digit.
Applied more often (according to the examples I have) in white crayon marker
Offline Rossco
« Reply #4 on: September 09, 2017, 05:06:33 PM »
Cheers Jeff great info once again
« Reply #5 on: September 09, 2017, 05:14:26 PM »
Now remember there would be markings on the carburator and possibly the distributor Separate from the engine assembly markings ;)
« Reply #6 on: September 09, 2017, 05:29:48 PM »
REQUEST  to other viewers: Please do not use or copy these onto your car unless it is a 1967 with a 390 or 428 originally installed. Every time we share these details they turn up on something completely different. For that reason I often don't share them in public but will give this a try.
Here you go Rossco - this should help
Offline Rossco
« Reply #7 on: September 09, 2017, 06:44:08 PM »
Jeff
what can I say.... greatly appreciated, I understand the value of these photos
Ross
Offline rodster
« Reply #8 on: September 10, 2017, 12:08:23 AM »
Upper right photo looks very familiar.    No need to copy when you have the original.   ;)
Jeff has an amazing collection of photos!
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #9 on: September 10, 2017, 05:46:27 PM »
As you know one of my sources (of which there are many) are the good owners that have shared their findings over the years.
Don't say if often enough THANKS  to all that have sent, posted and otherwise shared their findings and information over the last 40 years or more
And it's not just the pictures or information it's having invested allot of time labeling and organizing so that they can be found and shared with some ease. As I've said before - a picture is useless without when and where (car data)  it came from   8)
Offline rodster
« Reply #10 on: September 10, 2017, 09:53:56 PM »
And for that we have to give you a big THANKS. The time and effort you put into this is amazing.
Submitting a picture to you is the easy part.  ;)
1984 SVO - 2A
Offline brennancarey
« Reply #11 on: September 11, 2017, 10:05:11 AM »
Thanks... I find it interesting that the shades of blue are so varied on those pics.
67 GTA 390 Fastback
Dark Moss Green
Dearborn
Build Date 12/28/66
« Reply #12 on: September 11, 2017, 02:45:49 PM »
Would not suggest that is a great take away or the colors you see are correct and true.  The difference is likely just the camera settings and other things that take place when you take and use digital tools to save and manipulate photos as we've warned/mentioned before
Offline preaction
« Reply #13 on: September 12, 2017, 05:20:08 PM »
Jeff, have you determined a meaning for the numbers ?
« Reply #14 on: September 12, 2017, 05:34:20 PM »
Best guess would be that it identified with an final inspector or the line the engine was assembled in. We already have the initial of the assembler on the completed engine so not much left
