Author Topic: Sept 64 289 Convertible questions  (Read 1970 times)
Offline 66RavenGTCoupeAgain
« on: August 20, 2018, 09:34:06 AM »
Hi guys,
Can anyone help me with my SJ car? It has power steering and AC. These things have been haunting me and my build for a while now.....
I'd just like to know:
What colour my shocks should be?
Should the fuel line run behind or in front of the distributor and which bracket should I use?
Should I use 1 or two starter motor cable brackets?
Where should the coil be mounted?
And where should the engine tag go?
Thanks in advance.
66 Metuchen NJ  GT Coupe
Raven with Deluxe Black Int 289 A Code C4 PS Tinted Windows (Green) Dealer installed Rear Speaker
6T07A1612## Dec 65 Build
65 San Jose CA Convertible Rangoon Red with White Int and Power Top with plastic rear window 289 C Code C4 PS PB AC Fog Lights
5R08C1496## Oct 64 Build
Offline mmsnyr8120
Re: Sept 64 289 Convertible questions
« Reply #1 on: August 20, 2018, 12:58:31 PM »
give Matt a call.  our SJ Sept. 17 1964 conv.   9895395660
« Reply #2 on: August 20, 2018, 03:35:38 PM »
Semi-gloss black
Which bracket?? there is only one bracket and clip that I'm aware of
At least on this examples -  one
Passenger head at the front surface above and slightly to the inside of the alternator location
PASSENGER (Thanks Charles) side intake manifold
« Last Edit: August 21, 2018, 12:40:25 AM by J_Speegle »
« Reply #3 on: August 20, 2018, 05:19:59 PM »
If the part number on the cable assembly is C5ZF-14431-A (or -B), there are two cable clamps. In 1966, the cable assemble was C6DF-14431-A using only one clamp. I found an original C5ZF-144312-A on my Oct 65 San Jose Fastback. (It said Canada on it as well.)
« Reply #4 on: August 20, 2018, 05:28:37 PM »
Jim - have to disagree. Are you basing your comment only on your one examples or do you have more vin's/cars to support it?
I found plenty of examples with a single from mid summer to early 65 at San Jose and other plants - the basis for my statement.
There does not seem to be a consistent (always) pattern on these just going by the majority and the close other examples and evidence found on them. Picture posted is from another Oct 64 San Jose fastback and it only had one.
« Last Edit: August 20, 2018, 05:31:16 PM by J_Speegle »
Offline ChrisV289
« Reply #5 on: August 20, 2018, 06:03:23 PM »
What power steering unit are you running?  I assume the eaton pump but is it the remote reservoir or the one with the brackets to make it sit lower?
2009 V6 Mustang Coupe
« Reply #6 on: August 20, 2018, 11:53:03 PM »
On the intake drivers side front
'65 (alternator production) usually would have engine tag on passenger side of intake.
« Reply #7 on: August 21, 2018, 12:21:12 AM »
This is an October 65 build 66 Mustang that had an old starter cable assembly, C5ZB-14431-A, with two brackets and a "disintegrated" insulation sleeve, so I replaced it with a reproduction assembly of the same assembly number. I assume that I had a situation of Ford using up old stock, a 65 part on a 66. This was discussed with the two previous owners who told me what they had done to the car before I bought it. To continue this a bit further, 64 Mustangs, 260 and 289 engines, used part number C4ZF-14431-A (or -B) that is shown with one bracket in the 64 Electrical Assembly Manual. I again will state - one or two brackets depends on the assembly part number. An early 65 may have used a 64 cable to consume existing stock, hence one bracket.
When the part in question found on a car reflects the part number on the Ford Assembly Drawing, you have accept it as accurate. A picture might be worth a 1000 words, but the part number is the final deciding factor.
« Reply #8 on: August 21, 2018, 12:24:56 AM »
This is an October 65 build 66 Mustang ................
Maybe that is at the core of the difference since the period in question is Sept 64
Guess just a point were we're going to agree to disagree. But that's ok.  Your referring to the cable while the question is the retainers/brackets that connect to the motor mounts.
« Last Edit: August 21, 2018, 12:34:37 AM by J_Speegle »
« Reply #9 on: August 21, 2018, 12:41:02 AM »
Thanks ;) - took a bit to find one but corrected my post above
« Reply #10 on: August 21, 2018, 12:41:45 AM »
RH, opposite side...
Offline rocket289k
« Reply #11 on: August 21, 2018, 12:45:32 PM »
Should be be expected / hold true for all plants Charles for '65 (alternator production)?
Regards,
Ron
« Reply #12 on: August 21, 2018, 03:49:45 PM »
Yes, standard practice, it later was changed to the location Jeff noted.  I assume beginning of '66 production, but would be a good discussion item for another topic.
Offline rocket289k
« Reply #13 on: August 21, 2018, 04:12:17 PM »
Thanks Charles - I wasn't aware of that nuance (for Alternator equipped '65s).  I learned something new today.  In addition, is the passenger side also used for generator equipped cars?
Regards,
Ron
« Reply #14 on: August 21, 2018, 06:25:08 PM »
On V8 generator cars, the engine tag was usually mounted at the temp sending unit since coils were mounted to the top of the intake.
