Author Topic: 1968 Disc Brake Caliper Safety Wire  (Read 2822 times)
Offline CT428CJ
« on: September 12, 2018, 11:19:00 PM »
Off topic but where did you find the safety wire?
NOTE: this post was separated from another thread
http://www.concoursmustang.com/forum/index.php?topic=18719.0
« Last Edit: September 16, 2018, 05:25:28 PM by J_Speegle »
Re: 1968 Disc Brake Caliper Safety Wire
« Reply #1 on: September 12, 2018, 11:25:54 PM »
Think I purchased my last roll of black oxide plated bailing wire from OSH. Lasts a long long time.
I don't use the fancy special pliers - workers didn't use them so I don't plus owners/builders often wrap them too tight, evenly or too many wraps
Just my observations based on unrestored cars
« Reply #2 on: September 14, 2018, 11:17:22 AM »
I got the 5 pound roll of black oxide .040" steel baling wire at a yard sale for $1. I suspect that it can be bought at a feed store in rural areas. It appears to be the same wire that Ford used originally.
Looks like Tractor Supply sells a 3.5 pound roll calling it "Rebar wire"
https://www.tractorsupply.com/tsc/product/rebar-wire-16-ga-35-lbs?cm_vc=IOPDP1
« Last Edit: September 14, 2018, 11:36:06 AM by RoyceP »
Offline preaction
« Reply #3 on: September 14, 2018, 04:09:11 PM »
Jeff, would Royces pic above of the safety wire installed be typical ?
« Reply #4 on: September 16, 2018, 04:47:15 PM »
For 68 at Dearborn?  Let me look at my pictures
From the first post IMHO at least the one to the left is not like any I've seen since it would allow the bolt to loosen and the safety wire would not limit its movement as designed and the wire is laid over the spindle stop that was originally machined and is designed to contact the stop on the end of the strut rod. In it's current location it runs the risk of being smashed or cut by that surface bottoming out on a hard turn
As mentioned will find some pictures
« Last Edit: September 16, 2018, 04:51:14 PM by J_Speegle »
« Reply #5 on: September 16, 2018, 05:46:11 PM »
Have some pictures of the spindles on and off cars so unfortunately don't know the specific year and plant for each. Do know that one of the upper and lowers are from a 69 Darborn unrestored example
As you will notice the thickness of the wire used, its location as well as routing and that it was likely tightened with some form of pliers but not the fancy style many use today that produces allot of nice neat wraps. Ends were often left fairly long just right for grabbing cleaning rags and scratching hands and arms :(
Upper bolt-
68 NJ example
And another
Lower bolt-
Offline preaction
« Reply #6 on: September 16, 2018, 06:23:38 PM »
Great pics and information thanks. And post title.
« Reply #7 on: September 16, 2018, 07:19:07 PM »
The fancy pliers Jeff is referring to are specific for making it easy to twist safety wire which is used in racing and aircraft applications to name a couple. https://images-na.ssl-images-amazon.com/images/I/81r6W%2B97XML._SX679_.jpg
Offline CT428CJ
« Reply #8 on: September 19, 2018, 11:34:47 PM »
Excellent information, thanks!
Not only that but the wire is in stock at my local Tractor Supply.
« Reply #9 on: September 20, 2018, 02:36:35 AM »
Remember to oil it before you put it on. So much easier that way ;)
Offline Daisy
« Reply #10 on: September 24, 2018, 04:37:08 PM »
As a USAF SNCO mechanic - I would have jacked an airman for most of those safety wire examples! :O
Proper safety wire is an art... ;)
Daisy is a 1967 Mustang Coupe
Frost Turquoise
White Vinyl Top
390/C6
Online jwc66k
« Reply #11 on: September 24, 2018, 07:24:30 PM »
As a civilian contractor working on USAF tracking stations, you would have been walked off the site. Using "un-calibrated" safety wire pliers would have had the same results. There were a lot of other forbidden, "un-calibrated" tools on the list. Cars are not covered by the same safety and quality standards as the USAF (or USN). Still, old habits are hard to brake.
« Reply #12 on: September 24, 2018, 08:35:59 PM »
Well played, Sir...
« Reply #13 on: October 01, 2018, 06:18:45 PM »
Found a few rolls still on the shelf at our local Orchard Supply the other day - Annealed Wire -  when I was checking out the Going out of Business sale all stores are having. Looks like the same stuff we've used for years for this application and hanging parts. Would work IMHO for the 69 "Big Suspension" ID wire wraps also
« Reply #14 on: October 01, 2018, 07:26:43 PM »
Also notice the wire diameter. The wire we very often see when judging in concours is too thin.
