Author Topic: Rear Brake Drum Hung Up-Can't Remove  (Read 4268 times)
Re: Rear Brake Drum Hung Up-Can't Remove
« Reply #15 on: November 22, 2020, 10:12:04 PM »
Thanks for the actual date too. That helps me (and others) see why your car has certain features.
« Reply #16 on: November 23, 2020, 06:12:47 AM »
I mean in "Forum Profile => signature" so it shows up like mine-- in your signature..
...Good to see the two square holes in your drum as found only on original 2 1/2" Shelby drums. Unless you have pedal pulse, grooves  or other issues I would only sand the inside of the drums. No sense in removing any material from these.
Your "Signature" can be added by editing your profile settings.
I agree, machining the drums will remove A LOT MORE material than you think. Bills suggestion is solid. I would hesitate doing it if not absolutely necessary.
