Author Topic: 428 CJ Oil Pan Windage Tray  (Read 1061 times)
Offline Angela
« on: January 01, 2021, 08:14:35 AM »
Does anyone have an oil pan windage tray for a 428 CJ they'd be willing to part with?
I am aware there were changes made to the windage tray throughout production. My application is 1970 428, built October '69.
Re: 428 CJ Oil Pan Windage Tray
« Reply #1 on: January 01, 2021, 08:20:47 AM »
I searched the MPC and, referencing the attached picture, came up with C9ZZ-6687-A
Then I googled that part number, and the first hit looks like it has the information you need:
https://www.428cobrajet.org/id-oilpan
Just another example of how the MPC, and the Ford part number, can be very useful.
« Reply #2 on: January 01, 2021, 12:02:03 PM »
I think the one you are looking for with the notches on the sides is the easiest to find original. You will find 10 of the used originals with the notches to every one of the earlier type without the notches. I think most of the after market versions do not have the notches. The notches have to do with clearance for starter cable mounting in 1970.
« Last Edit: January 01, 2021, 12:06:54 PM by Bob Gaines »
Offline rustbucket
« Reply #3 on: January 03, 2021, 03:16:41 PM »
I have an NOS one in the box,
i will see what part number is on the box and what style it is, and post pics if possible
Offline rustbucket
« Reply #4 on: January 05, 2021, 12:18:28 AM »
here is the one i have,
let me know if this is the one youre looking for
« Reply #5 on: January 05, 2021, 12:32:09 AM »
Your pictures are of the 70 style with the cut outs on the passenger side edge.
Offline keeper
« Reply #6 on: January 15, 2021, 05:40:35 PM »
I NEED ONE FOR A 1969 SCJ Built Dec.15,1968. How critical is it to have the exact tray in the technical sense. In other words will an after market tray or one  for a 70 work on the 69?  :)
Keith 69 Mach1TopLoader/Vcode SJ
« Reply #7 on: January 15, 2021, 06:36:14 PM »
The 70 version will work the same as the 69 however a sharp eye can tell that it is the 70 version tray by looking at the passenger side gasket mating area.. The 70 version had cut out notches along the passenger side for clearance of starter cable brackets mounted on the block starting that year.The 69 version follows the contour of the pan gasket with no notches.  There are several different aftermarket companies making functional versions. They will all pass for the 69 version once installed given they do not have the notch cut outs on the passenger side edge. Remember the oil pan and windage tray were installed before the engine was painted if you car about the historical look.   If buying used Ford you will find 1 69 version to every 10 or 15 1970 versions.
« Reply #8 on: January 15, 2021, 07:30:28 PM »
Sent you a PM.
Offline keeper
« Reply #9 on: January 16, 2021, 01:16:51 AM »
Thank you Bob and Royce for the excellent information. I now have a much more clear plan to proceed with. The ability to determine which tray is in service and know which one it is is very helpful. Thank you so very much.
