Author Topic: 1970 Mach1 Trunk Pinch Weld Cover  (Read 1675 times)
Offline alanmac
« on: February 04, 2021, 08:10:42 PM »
Hi all; I remember seeing a rubber protector cover over the left side wheel well pinch weld.  Does anyone know where to purchase a good repop?  Thanks Alan
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
Offline alanmac
Re: 1970 Mach1 Trunk Pinch Weld Cover
« Reply #2 on: February 04, 2021, 08:31:45 PM »
Thanks, For you that are familiar with this part, how close is it to original? My Mach1 was built October 7, 1969 at the Metuchen plant.  Would this part be assembled on my car?   Alan
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
Offline HDAshmore
« Reply #3 on: February 04, 2021, 11:09:46 PM »
Browns restoration in Missouri makes great repops.
http://www.brownsautobodyservices.com
Call them, they are nice to deal with.
Dan
« Reply #4 on: February 05, 2021, 12:07:52 AM »
Welcome Alan
quote author=alanmac link=topic=24144.msg150444#msg150444 date=1612485105]
[/quote]
Glad you added when and where your car was built. Likely many details it makes a difference. Might consider adding when and where your car was built to your signature so you don't have to type it each time you ask a question.
Yes your car would have received on as long as it was not built for delivery in Calif. Most common for that plant in 70 would be the gray version rather than the black based on other cars.. Its placed over the inner to outer drivers side wheel house halves. Picture is from another thread on the subject
Offline alanmac
« Reply #5 on: February 05, 2021, 01:09:30 PM »
Thanks everyone for the responses. Jeff, I added my car info to my profile as you suggested.  My car was delivered to a Duncannon PA dealer, so the gray color is likely correct.  Also what length should it be 8.5"?  also I see a wire tie fixing the rear light harness to the pinch weld below the luggage protector.  Is there anything specific about the wire tie?  Any recommendations?  Alan
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
« Reply #6 on: February 05, 2021, 05:36:59 PM »
The wire tie is similar in appearance to a generic wire tie except the one Ford used was made and had a trademark of Panduit.
« Reply #7 on: February 05, 2021, 05:43:59 PM »
Don't know that I have a 69-70 handy nor the measurements
As for the nylon tie. The one I have is just over 6" in length and used at all three plants 69-70. Held the fuel sender wire in place.
Though for a different plant there are some addition pictures in the thread below
http://www.concoursmustang.com/forum/index.php?topic=19842.msg125411#msg125411
Offline alanmac
« Reply #8 on: February 05, 2021, 07:02:57 PM »
Thanks Jeff, I appreciate your feedback.  Dead Nuts has the gray luggage protectors and panduit wire ties.  They have some pictures of both 69 and 70 unmolested cars and they say the protectors are typically 10-11 inches in length.
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
« Reply #9 on: February 06, 2021, 12:28:49 PM »
Coupe and vert was longer than fastback.
Offline alanmac
« Reply #10 on: February 07, 2021, 02:15:19 PM »
Has anyone measured the length of the fastback luggage protector?
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
« Reply #11 on: February 07, 2021, 02:31:06 PM »
see pic
Offline alanmac
« Reply #12 on: February 07, 2021, 03:59:35 PM »
Awesome 67GTA289, Thank you!
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
« Reply #13 on: February 07, 2021, 04:36:43 PM »
You'll know pretty quickly if its too long :)  As you can see it pretty well covers the complete visible length
« Reply #14 on: February 08, 2021, 10:54:49 AM »
John your photo showing lenght is from coupe vert around 10 1/2''   fastback is around 8 1/2''  from what i remember.
