Author Topic: April 69 San Jose Front Fender Marker Light Wire Routing and Clip  (Read 1775 times)
Offline svo2scj
Hi Guys (if you have been following on 428cj) ...I've started to make right what I didn't wrong in restoring my car 15 years ago!!!
Links are dead and photos are gone (for most/not mine and I didn't pay photobucket)!   REVIVING this topic https://www.concoursmustang.com/forum/index.php?topic=4689.msg26391#msg26391
I'm almost positive the end result of Jeff's photos back then was that SJ cars man not have gotten the "clips" Jack now sells for the front valance.   When I did my car I didn't use them.   Have we learned anything new in 12 years??
Mark
« Last Edit: February 22, 2022, 04:33:47 PM by J_Speegle »
Offline rockhouse66
Re: April 69 San Jose Front Fender Marker Light Wire Routing and Clip
« Reply #1 on: February 21, 2022, 08:30:24 PM »
I will repeat what I have reported before.  My 3/69 unrestored SJ car had the zip ties and not the plastic retainers/clips.
« Last Edit: February 22, 2022, 04:34:20 PM by J_Speegle »
'66 GT FB
Offline svo2scj
« Reply #2 on: February 22, 2022, 10:28:57 AM »
Perfect !  I knew I had seen this and WHY doing my 4/22 car didn't use them!
It's funny I told Gary "I was very honest showing I didn't have a front valance when I got my car" (As well as stating it had a 351C)!    This is why there is a ZZ service valance and the number is showing.
Glad you saw this and GLAD i didn't ask on FB !  LOL
Mark
P.S.   It is also why I didn't restamp the block ...in my case I SAID I didn't have it.  (Others are restamping POORLY and claiing they did!)
« Last Edit: February 22, 2022, 04:34:12 PM by J_Speegle »
« Reply #3 on: February 22, 2022, 04:45:34 PM »
Per the "1969 Mustang Electrical Manual" (AM0028 pg 3) the Ford part number is 351453-S, strap, 2 required. However, the manual has the incorrect Ford part Number. It should be 351053-S. It is carried by AMK.
It is a legitimate use, just poorly documented.
Get a set of the Assembly Manuals for your car. You can thank me later.
Manuals are your friends.
« Reply #4 on: February 22, 2022, 04:59:15 PM »
Adjusted the title and moved the thread over to the General 69 Section since that is where the Dearborn discussion thread on the subject is also
Will look through my pictures again to see if I have anything new to offer. right now (bit off thread) not many have the zip ties so far. Will report back
Jim. What date is on that revision page and does it show the zip tie?
« Reply #5 on: February 22, 2022, 05:12:18 PM »
Doesn't the rubber sleeve come into play with the wiring and zip tie?
« Reply #6 on: February 22, 2022, 05:18:20 PM »
In what way?
If your thinking of it keeping the rubber sleeve in place its too far towards the frame for that. In other years there is a small weld bead that holds the sleeve up towards the outer end. Don't recall at the moment if 69 has that added detail
Zip tie appears (and when used) to hold the marker light up out of the way
« Reply #7 on: February 22, 2022, 05:26:34 PM »
The page is dated 10-16-68 and the Ty-Rap is item 27 (to the right of center in the middle, the page is not a good copy). No installation instructions are given (as in loose, snug, use tool, etc).
Offline 7Lscjracer
« Reply #8 on: February 22, 2022, 09:57:31 PM »
My Nov. '68 built San Jose Mach 1 I bought unrestored in May '81 came with the wire clips
Bought May '81, sold Sept '20
« Reply #9 on: February 23, 2022, 12:05:55 AM »
Just thought we should clarify and identify the wire retainer I believe we are discussing in this thread
Dearborn not a San Jose unrestored car
« Last Edit: February 23, 2022, 05:08:50 AM by J_Speegle »
« Reply #10 on: February 23, 2022, 12:13:38 AM »
Only found a couple of cars where I still had the fenders installed on the car and pictures of that area. Not wire retainer/clip at marker
9R131xxx Approx first part of Nov 68
9R175xxx Approx first part of May 69
« Last Edit: February 23, 2022, 12:19:37 AM by J_Speegle »
Offline Shelby50069
« Reply #11 on: February 23, 2022, 02:38:07 AM »
Pictures of my previously unrestored San Jose Jan 69 build
« Reply #12 on: February 23, 2022, 05:09:08 AM »
Sure seems like a pattern
Offline 7Lscjracer
« Reply #13 on: February 23, 2022, 02:37:29 PM »
Yes those are the clips Jeff.
9R02M123247 was my car that had them but no zip ties so perhaps they were substituted as a quick and easy alternative to the clips.
« Reply #14 on: February 23, 2022, 02:44:14 PM »
Since we have at least one other plant using the clips and the zip ties  and they are in different sections of the wire I don' think that one replaced the other. Since you have an earlier car than the rest guess we need to find some additional earlier ones to see if this is a running change - used them at the beginning of production then, for some reason, they weren't
Hunt goes on
