Author Topic: 1970 power Steering cylinder  (Read 551 times)
Offline BHStang
« on: March 08, 2022, 10:22:02 AM »
Looking for an original rebuildable core
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
AC, PS, Power disk, Shaker, Rear Spoiler
Offline DougDyar
Re: 1970 power Steering cylinder
« Reply #1 on: March 08, 2022, 07:58:36 PM »
I have one. PM me.
Doug
0F02G203277
« Reply #2 on: March 08, 2022, 10:38:38 PM »
Did it need to be dated coded and if so what are you looking for?
Offline BHStang
« Reply #3 on: March 09, 2022, 01:49:19 PM »
If I recall the 1970 cylinder is unique to 1970 beyond that date code is not important to me.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
« Reply #4 on: March 09, 2022, 02:33:54 PM »
What do you recall is unique about the 1970 cylinder ?
« Reply #5 on: March 09, 2022, 04:06:25 PM »
Pump and reservoir are the only things unique on a 1970, with 302 or 351 engines.
Not sure about 6 cylinder power steering.
« Reply #6 on: March 09, 2022, 04:24:46 PM »
67-70 uses a fair number of interchangeable parts. Including the cylinder.
There are major differences with 351C/Boss parts (pump, bracket, hoses and end fitting sizes) as compared to the 351W  and the drag link is specific to 70 Mustangs as the tie rods got bigger.
Offline BHStang
« Reply #7 on: March 10, 2022, 01:00:16 PM »
Interchangeable yes but I think there was some manufacturing difference in the tube in 70 but maybe not.  I dont have any in hand to compare so they might be exactly the same but for a date stamp.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
« Reply #8 on: March 10, 2022, 02:53:18 PM »
If Ford changes anything on a part it almost always changes the part number.
So if the part did change it would most likely have a different part number in the MPC.
D0Z would be the first three numbers in the MPC for a changed part happening in 1970 for Mustang.
But Ford (all the way through this final publication in May of 1975) indicated the use of a C7ZZ part as shown in this snippet of that publication.
